fuel filter
Posted: Tue Jul 10, 2007 7:10 pm
by v84x4
any idea what type of inline fuel filter i should use on my efi system
Posted: Tue Jul 10, 2007 10:46 pm
a big one.
do you need any special fittings ? or simply push on ?
Posted: Wed Jul 11, 2007 7:10 am
by v84x4
i think push on should be fine
Posted: Wed Jul 11, 2007 10:54 am
Well, if using push on on the high pressure side, ensure any rubber hose used, is capable of withstanding the high pressure within an efi system, say 40-50psi is quite normal.
I know that Subarus use a nice compact in-line filter with 8mm hose tails for push on hose.
Prettty much any Subaru turbo from 1990-2001 for definate, although I think even the newer cars use the same filter.
Its a round filter, similar size to a smallish diam oil filter, with hose tails on top.
Obviously this is a filter intended for use before the fuel rails, NOT before the pump itself.
I assume this is what you are looking for ?
Posted: Wed Jul 11, 2007 10:56 am
by v84x4
it sounds just the thing thanks
Posted: Thu May 01, 2008 12:55 pm
by landrovernuts
Early range rover efi fuel filters are large, flow plenty of fuel, have push on 8mm tails and from your local car parts emporium are cheap as chips.
Just put one on my newly converted 90 (4.3) and works at treat and only cost £3.49 and its a Fram filter aswell.
Toby
Posted: Mon May 05, 2008 10:05 am
by v84x4
thats the puppy cheers
