Cooling system tr7 v8 efi
Andrewrv8
Post by Andrewrv8 » Sun Jan 06, 2019 1:31 pm
Hi folks, getting my tr7 to this stage has been a long drawn out process , but getting to the final stages now, hopefully up and running in the next month or two. I know there are plenty of v8 efi tr7's about, I was wondering if anyone has a design or some useful pics they'd be willing to share with me. It's the hotwire efi with megasquirt (intermediate timing cover) if that makes any difference. Thanks!
Triumph TR7 V8 3.9efi
Re: Cooling system tr7 v8 efi
Post by SuperV8 » Thu Jan 17, 2019 1:28 pm
There are so many custom coolant systems out there - might be best if you post up a few pics of your engine bay/radiator/header tank/heater matrix etc.. - then people can chime in with suggestions?
Andrewrv8
Post by Andrewrv8 » Mon Jan 21, 2019 1:19 pm
Tom, yes I will get onto that - not a bad shout. Once I work out how to upload pics I will do so. Cheers :D
Post by SuperV8 » Mon Jan 21, 2019 3:02 pm
Save the photos to a free photo hosting site - then copy the correct sharing links into your post and the photos appear.
I use Flickr but there are many others.
Post by scudderfish » Mon Jan 21, 2019 6:02 pm
If you select the attachments tab below, you can add photos (and other files) directly into your post. Add the file, then click the 'Place inline' button.
Post by SuperV8 » Tue Jan 22, 2019 8:01 am
Ah good to know.. Learn something new every day :)
Andrewrv8
Post by Andrewrv8 » Tue Jan 22, 2019 7:59 pm
Right then, I'm going to have a go at attaching some pics. Thankyou for the tips .
More to follow in my next post :mrgreen:
Andrewrv8
Post by Andrewrv8 » Tue Jan 22, 2019 8:03 pm
Andrewrv8
Post by Andrewrv8 » Tue Jan 22, 2019 8:06 pm
Hopefully on the road for summer!
Post by SuperV8 » Wed Jan 23, 2019 8:07 am
What thermostat housing are you using?
What do the seals on your cap look like?
Are there only two ports on the header tank, the larger lower one - and the smaller higher one?
Post by SuperV8 » Wed Jan 23, 2019 3:14 pm
This is the heater matrix outlet to go to your heater.
The heater return needs to tee into the bottom hose to go back into the pump inlet.
This is your pump inlet
This is probably your Rad outlet,
What is the lower port - can't see from the photo?
Andrewrv8
Post by Andrewrv8 » Wed Jan 23, 2019 4:44 pm
The larger outlet is on the bottom.
The attachment 15482616185877113022471458664385.jpg is no longer available
The attachment 15482617129575947144935988477211.jpg is no longer available
Andrewrv8
Post by Andrewrv8 » Wed Jan 23, 2019 4:46 pm
I'm happy to lose heater, as it's a track day car, if this simplifies things.
I like the thermostat cover with temp sensor possibly to connect with electric fan?
Andrewrv8
Post by Andrewrv8 » Wed Jan 23, 2019 4:49 pm
Andrewrv8
Post by Andrewrv8 » Thu Jan 24, 2019 4:14 pm
Thanks, unfortunately I can't see the pics, which is a shame.
Could I simplify the whole thing, top hose to thermostat housing, water pump to bottom rad. Outlet above this to lower outlet on header tank.
Blank off heater outlet, and top outlet from header tank.
No heater, but should work, and should bleed ok?
Or isn't it that easy?
Thanks Andrew
Return to “Cooling Area”
