Rover SD1 Clutch Slave Fitting
Posted: Fri Dec 07, 2018 1:23 pm
by bigdawgv8
Hi All,
I’ve just bought a genuine SD1 clutch slave cylinder off the Bay of E.
The port for the flexi pipe appears to be about 1/2 inch diameter but isn’t unf so assuming it’s metric fine?
Can anyone confirm the thread size please?
Thanks for the help.
Re: Rover SD1 Clutch Slave Fitting
Posted: Mon Dec 10, 2018 9:11 am
by richyb66
Pretty sure it's 7/16" UNF
Posted: Mon Dec 10, 2018 10:29 am
by harvey
richyb66 wrote: Mon Dec 10, 2018 9:11 am Pretty sure it's 7/16" UNF
It's not UNF, because I used an SD1 slave cylinder on a P6B 3500S LT77 conversion and I had to fit the SD1 fitting on to the end of the clutch hose.
I'd say it's a fine Metric.
Posted: Mon Dec 10, 2018 11:07 am
I'm fairly sure all the SD1 brake etc fittings are metric. But there is a UNF size very easily confused with it, and even has the same TPI, so sort of fits.
Posted: Mon Dec 10, 2018 1:24 pm
by ged
M12 X 1 definitely as I've just measured a spare.
Posted: Mon Dec 10, 2018 1:59 pm
by DEVONMAN
7/16" unf is the size of the thread on the very similar cylinder used on Defenders etc.
Genuine SD1 cylinders have an M12 thread.
Posted: Mon Dec 10, 2018 4:20 pm
by richyb66
I'm amazed anyone at rover in the 70's knew what a metric thread was.
When I fitted my helix clutch last winter I had to swap the SD1 Master Cylinder for a bigger bore Defender V8 one because you couldn't physically press the clutch pedal. The inlet sizes were different so I ended up getting a new hose made - they don't make these things simple do they?
Posted: Mon Dec 10, 2018 4:38 pm
The SD1 is of course BL rather than Rover, and was designed when metric was coming in. Pretty well all of it is metric, except the RV8.
