Recommend fuel pump
James 33
Recommend fuel pump
Post by James 33 » Tue Aug 07, 2018 6:55 am
Can anyone recommend a good fuel pump to feed an Edelbrock 500 on a 3.9 RV8. My Facet Red top packed up yesterday after only 5k miles of use so not too impressed with those. Thanks.
koopsterman
Re: Recommend fuel pump
Post by koopsterman » Tue Aug 07, 2018 7:26 am
Hi James, the Holley "red top" is a good pump and will keep up with the demands of a 3.9 with ease, it is a noisy pump though even when sitting on rubber mounts, its around the £100 mark if my memory serves me correct, I hope this helps.
James 33
Post by James 33 » Tue Aug 07, 2018 1:53 pm
Thanks i managed to get mine going again now. I stripped it down and found it full of debris. Cleaned it all out and seems all ok again now. Quite like that its serviceable.
JP.
Post by JP. » Thu Aug 09, 2018 1:52 pm
Skip the Facet, they do not deliver enough for the 4-barrel carb. Especialy when they are hot.
Holley Red is what you need.
Facet Red Top 40 usGPH free flow. @ 7psi thats about 10 usGPH
Holley Red 97 usGPH free flow. At 7psi thats still 25usGPH
Those Facet pumps wear out fast, especialy on long journeys.
'73 Ford F250, 6.7ltr V8
Building a GT40 mk2
James 33
Post by James 33 » Thu Aug 09, 2018 2:12 pm
Thanks JP. Never noticed a problem with delivery. I do a lot of long journeys though and did notice wear on the piston when I stripped the pump down.
Post by Ian Anderson » Thu Aug 09, 2018 5:11 pm
Robrover
Post by Robrover » Wed Aug 15, 2018 8:16 am
I looked at all the well-known American pumps Summit was offering and Facet. Most were claimed to be rather noisy and some not too reliable.
So I ended up buying a Pierburg rollervane pump which is mounted inline on the crossmember outside the tank on my 4.6 with Eddy 500.
Supposed to support 340hp, rated at 3.9 - 5.5 psi, delivers 130 litres per hour (34.34GPH), self priming, lift capable, no return, very quiet, weighs 0.5kilo. I think they're OE on some Porsches.
Got it for AUD136 at Injectacarb
www.injectacarb.com.au
