Rover v8 4.6 piston identification
Posted: Mon Apr 30, 2018 4:38 pm
Is anyone able to identify these pistons? They came out of a 4.6, but im trying to work out what compression ratio they are as the engine number has been ground off.
Welcome to the well-known V8 Owners Forum, no matter what you drive if its V8 Powered you'll be made very welcome.
https://www.v8forum.co.uk/forum/
garrycol wrote: ↑Tue May 01, 2018 12:04 am They look like 4.6 low compression pistons but I cannot be sure - you can try measuring the volume of the dish - if it is less than 30cc it is hi comp and if it is over 30cc if is lo comp (I cannot remember the actual volumes - 2somthing is hi comp, 3something is lo comp.
Garry
