3.5 flapper throttle shaft needed SD1
Looking for that special part?
Post by Coops » Wed Apr 25, 2018 1:30 pm
has anyone got kicking around an undamaged throttle spindle/shaft from a SD1 3.5 flapper efi system?
must come from the plenum that uses the large round 3 bolt hole tps unit,
want it for my 3.9 plenum so i can run the later style tps that has the D drive like on the old 3.5 efi shafts did,
Rotrex C38-91 supercharger and Cossie RS500 Intercooler @ 14psi of Boost. 404 RWHP, (4.6)
New Forged 4.8 V8 kitted out with the dogs Cajones of parts and a procharger D1SC. 2017 :D
berty
Re: 3.5 flapper throttle shaft needed SD1
Post by berty » Thu May 24, 2018 6:50 pm
Hi don't know if this will help but I got complet set up from 3.5 vitess and a 3.9 range rover
Return to “Wanted”
