Timing problems
Posted: Mon Nov 28, 2016 8:14 pm
by paulsv8manta
Hi guys, finally got the engine running for the 20 min cam run in.
Now trying to set the timing with a strobe light, when i set the timing to 2 degrees btdc the engine runs really rough with the occasional popping.
When I turn the distributor back further to what looks like 30 degrees btdc the engine runs a lot smoother with no popping!
What am I missing?
Re: Timing problems
Posted: Mon Nov 28, 2016 10:16 pm
by Darkspeed
paulsv8manta wrote:Hi guys, finally got the engine running for the 20 min cam run in.
What am I missing?
Fuel - By way of it sounds like not enough - the weaker the mixture the more timing you will need - Also Popping !! - I take it you mean spitting back.
A weak mixture takes longer to burn than a rich one as the flame travels slower due to the lower charge density. Richen up the mixture and you need less timing.
2 degrees is however ridiculous - Unless for cranking (50rpm) on an ECU.
For idle timing 10-12 but this depends on the type of equipment.
My advice - 12 degrees and richer.
I ran 14 on mine but I had a non Vac dizzy stopped to 8 degrees dizzy advance.
Re: Timing problems
Posted: Tue Nov 29, 2016 9:30 am
What am I missing?
It may be a silly question - but are you driving the timing light off the correct cylinder?
No1 is the front nearside one. If that's correct, I'd check the TDC mark is actually at TDC.
