Rover v8 identification.
Posted: Tue Sep 06, 2016 9:46 am
Hello All,
I’m new to the forum, but I think all V8 specialist are here...
I have got a Rover V8 3.9L engine with 4X2 Dellorto’s 45 on them out of a Replica.
That's all a knew, up till recently when I opened the engine for replace head gasket.( I found water fumes coming out of crank case ventilation.)
Hope it is the gasket not the block.
Engine looks new inside.
So what I know until now (thanks to David Hardcastle book+ this site) :
Engine is 37A…. so a 350I from TVR/Morgan.
The bore is 93.5mm NOT 94..mm so this indicates an early JE-Engineering upgrade to 3.9L?
Omega pistons
Crane high rev followers
Double springs (I would say also from JE-Engineering)
Cam? No idea. Probably also crane. I will measure lift height later
Valve train from EFI (acc. valves) with as far as I could see standard rockers.
Inlet ports are widened to the max.
Questions:
Which Headgasket to use? I already ordered a 3.9L standard 94mm composite. Is this usable for 93.5mm? A 3.5L gasket from” Fel-Pro Permatorque acc Hardcastle” is advised acc Hardcastle book?
What power range could someone expect from this powerplant?
What would I put as max rev limiter for this set-up?
Could roller rockers be a further improvement?
Thanks for advice. I need the engine ready for next meeting in Spa Francorchamps “6 hours”…..
PS: Thanks to te moderators for this great forum
Omega pistons
Questions:
