Holley Or Facet Fuel Pump
Posted: Mon Aug 29, 2016 10:06 pm
by john 215
My Facet Red Top fuel pump has just shat itself this evening, outside lane of the A1 of all places ! while I am replacing it do you gents think its worth going for a Holley Blue top ? Or stick with a red top facet ?
A few details....Rover 4.6 with a weber 500 used for street use and pump mounted at rear.
Thanks for any thoughts,
Cheers John
Posted: Mon Aug 29, 2016 10:16 pm
by Prophead
I have no experience of the Holey but the facet is working fine for me. It does have to be mounted correct ideally vertical with the outflow higher than the inflow otherwise vapour / air can get trapped in the pump which will significantly shorten it's service life.
Posted: Tue Aug 30, 2016 4:30 pm
by Blown v8
I use the Holley pumps,reliable,BUT NOISY !
Posted: Tue Aug 30, 2016 7:51 pm
by Ian Anderson
http://roadcraftuk.co.uk/index.php?rout ... uct_id=348
Carter pump, reasonably quiet and can suck air without ruining itself.
Used a lot by GT40 crowd
Posted: Tue Aug 30, 2016 8:32 pm
by JP.
Facet Blue top on filterking for years.
Posted: Mon Sep 05, 2016 9:05 am
by Robrover
I use a Pierburg pump on my 4.6 with the Edelbrock 500 mounted down in front of the tank.
