Additional Vacuum take off
Posted: Tue Apr 12, 2016 11:04 pm
by paulsv8manta
Hi guys,
I need an additional two Vacuum take off's, one for the adjustable fuel pressure regulator and the second for the vacuum gauge.
There is only one at the moment and that's at the inlet for the distributor.
Can I drill and tap a new take off on the plenum chamber and if so is there an ideal location?
Many thanks.
Posted: Wed Apr 13, 2016 9:09 am
by SuperV8
Can you not just tee off the current vacuum?
Re: Additional Vacuum take off
Posted: Wed Apr 13, 2016 10:00 am
paulsv8manta wrote:Hi guys,
Many thanks.
If this is an EFI RV8. there should already be a vacuum take off for the fuel reg. I just added an additional one for the MS MAP sensor along side it. Found a suitable brass barbed tube threaded at one end from Demon Tweeks or similar.
However, if that is awkward, the trumpet base has three bosses where takeoffs are provided depending on model. Be easy to drill and tap those.
Posted: Thu Apr 14, 2016 12:32 pm
by SuperV8
I am using one vacuum take off from the plenum to both my MAP sensor and fuel pressure reg and dump valve.
Seems to work fine, Is there any advantage/reason I should have a separate take of point for each vacuum device?
Posted: Thu Apr 14, 2016 8:58 pm
by paulsv8manta
Thanks for getting back to me, I wasn't sure I could t-off the existing vacuum. thought it might impair the performance of the distributor.
Think I'll drill and tap the spare boss at the base of plenum.
Cheers Guys
Posted: Fri Apr 15, 2016 6:26 am
by DEVONMAN
paulsv8manta wrote:Thanks for getting back to me, I wasn't sure I could t-off the existing vacuum. thought it might impair the performance of the distributor.
Cheers Guys
You are correct, the distributor vacuum pipe should not be used as it will not give full manifold vacuum and would only give vacuum on light throttle. This is known as a timed vacuum port.
Posted: Fri Apr 15, 2016 6:29 am
by DEVONMAN
SuperV8 wrote:I am using one vacuum take off from the plenum to both my MAP sensor and fuel pressure reg and dump valve.
If your dump valve has a bleed system like the HKS two stage progressive type, then that should have a separate vacuum take off.
Posted: Fri Apr 15, 2016 7:14 am
by SuperV8
No, just a standard/simple dump valve, so i'll leave as is then, thanks.
