rover v8 timing/fuel/spark
Posted: Mon Mar 21, 2016 7:55 pm
Hi all, just a quick query about trying to get the timing right on my ex rover 3500 engine now fitted in a capri. its got an accuspark ingnition amp fitted in the distributor. Is there any way of double-checking the pulse from this lines up with the spark at the critical moment and do I need to?
The basic problem is that it idles beautifully, then when you rev it it looses power, pops and spits and doesn't pull under load and misfires popping and banging. Ive changed the plugs and leads, its not the fuel and I believe the carbs to be set up/running ok and have set the mixture ok.
Ive got a new coil on the way but The only thing I can think is it could be a timing issue. It does it whether the vacuum advance unit is operating or has had the tube pulled off and blocked up ? So I'm wondering if I need to try and change the position of the hall effect senor on the plate. Ive tried advancing and retarding the static timing with little joy. any suggestions welcome!?
cheers Barry
cheers Barry
