Strange noise......
Posted: Mon Jun 18, 2007 3:53 pm
I have recently changed the SU's on my V8 landy to a newer better condition pair of HIF 44's I changed the inlet manifold as well and the new one does not have a water pipe from it to the rear of the water pump, tempretures are the same as they where before and its not overheating. I have set up the carbs a bit on the rich side 4% at tick over and changed the needles I had fitted (BBW) as on the gas analyser it dropped to -0.2 at 2000rpm. So I have re profiled and old set of needles and it stays happily at 8% now when you build the revs up.
Thing is it has got a horrible tinkling sounds a bit like pinking but not quite? I thought it was because it was lean but it still seems to be there, its apparent under light throttle.
The plugs appear to be okay, not showing rich or too lean.. I have a feeling I might have the wrong plugs in its a High compression RR engine originally with the EGR disconnected.
What plugs should be in it? At the moment its on NGK V groove BP5E I think.
