Inlet Base Blanking Screws
Posted: Thu Sep 11, 2014 4:43 pm
by v8250
Guys,
Can you help me...have been trawling the net to buy 2no stainless steel planking plugs for the trumpet inlet base...but can't find a supplier. Standard units are steel 5/8"x1/2".
Any/all help greatly received.
Thanks, Andrew
Posted: Fri Sep 12, 2014 9:36 am
by MikB
I would probably think twice about putting stainless plugs in the aluminum base :)
http://www.corrosion-doctors.org/MatSel ... metals.htm
Posted: Fri Sep 12, 2014 10:20 am
I always use a decent thread sealer where bolts go into ally threads anyway.
Posted: Fri Sep 12, 2014 10:28 am
by v8250
MikB wrote:I would probably think twice about putting stainless plugs in the aluminum base :)
Mike , that's irrelevant.
All metals corrode/oxidize to some point. The main issue when using stainless steel [st/st] fasteners with an alloy is galling when tightening. The heat generated between the two metals causes their base state at the threads surface to change, with st/st surface now being prone to rusting. This is easily overcome by using an appropriate lubricant when tightening i.e copper grease or a loctite depending upon use of the fastener [set screw/bolt]. And to tighten the fastener slowly :. reducing both heat and friction.
Factory standard is a steel plug which is far worse than st/st. Brass/brass alloy plugs are often used which work well with alloys. Again a lubricant should be used.
So back to the original question. Anyone know of a UK supplier who sells these plugs in st/st?
Posted: Fri Sep 12, 2014 6:13 pm
by mike-b
Hi Andrew,
A company that makes just about any sized hose you require must also have adapters e.t.c
Have a look here, earls.co.uk the`re at Silverstone and all good quality I`ve found.
regards, mike-b
Posted: Sat Sep 13, 2014 7:05 am
by unstable load
Any hydraulic supplier should carry those in various materials.
Posted: Sat Sep 13, 2014 7:25 am
by v8250
unstable load wrote:Any hydraulic supplier should carry those in various materials.
Thanks John, I would agree but none of the hydraulic suppliers have them in 5/8". Even my local Co', Unimaster, have no 5/8" plugs in st/st.
The search continues...
Posted: Mon Sep 15, 2014 8:42 am
by SuperV8
Can't you just use stainless button head bolt, loads on google.
Guessing it's UNF? Here's a steel one.
http://www.ebay.co.uk/itm/like/13112773 ... 108&ff19=0
Posted: Mon Sep 15, 2014 9:22 am
by v8250
Thanks Tom, no, I want a proper seal provided by a copper washer behind the plug head. So the search continues...
