Bosch 044 pumps
Posted: Tue Mar 11, 2014 10:57 pm
by JJMclure
Been looking at the above on fleabay and found one for 87 plus postage which seems a fair bit less than anyone else, is there a way to tell if its kosher or a knock off?
Posted: Wed Mar 12, 2014 4:07 pm
by JP.
I have some cheap knock off on the car ( about 50 quit incl P&P) and it holds fine.
Its even on overrun as I only use 1 bar max ( 0.2bar on cruising ) and the rest gets bypassed back on the return hose.
Its on for 6000 mile now where a genuine big name brand high dollar let go already after 500 mile cause it got overheated by not getting pressurised enough ( so it keeps running high revs..).
Use one on my turbocharged carburated Capri.
The pump still does 6.5bar while testing it.
Posted: Thu Mar 13, 2014 12:47 pm
by Eliot
Ensure you have a 10 micron post pump filter, so if you cheap pump does destroy itself, it doesn't ruin your injectors.
I've paid around £120 for my 044's in the past, not really sure how you are supposed to spot a kosher one though.
