Thanks for the reply, very informative
I'm actually quite far into the build now, it's a 1979 BGT so late spec engine bay.
I've fitted blue poly bushes to the rear along with a pair of telescopic dampers and anti-tramp bars. The axle has been fitted with the V8 ratio crown wheel & pinion. The springs are multi-leaf lowering springs although I forget the height.
Front suspension is standard dampers, polybushes and slightly lower/stiffer springs. I do plan to fit a bigger anti-roll bar but will do so once the car is on the road. I bought standard new calipers with some greenstuff pads, how do the V8 brakes differ?
I plan to use the Hotwire EFI from a Range Rover, although a carb is tempting I already have all the EFI equipment and would like the reliability of EFI. I will be using the RV8 style manifolds. What timing cover did the RV8 use, from what I can find out it was the Range Rover one? If it won't fit I will need to find a P6 front cover.
Gearbox will be an LT77, I have already trial fitted the engine & gearbox and modified the gearbox tunnel accordingly to clear the top of the gearbox.
I've seen a few conversions some with and some without the steady bar, I was going to try without one but I could make something to go from the head to the wing once I have the engine fitted.
I will need a new rad, so that's on the long list of expensive parts I need, although not quite yet.
The 3.9 is a interim serpentine engine so does have a long-nose crank, I converted a 4.6 to early cover to go in a 2 door range rover a few years back and remember using a spacer then too. I can probably machine something up on a lathe.
The body has had a load of new panels, spent a year doing the welding, it's nice to be done with that now. I'm removing the rubber bumpers and fitting the smooth sebring valences front and rear.
Here's the most recent photo;
Excuse the large metal spike from the back end, I'd just taken it off the spit-jig from the welding.
