Mls exhaust gaskets
Posted: Sun Feb 02, 2014 8:57 pm
by Discopotatoes
Does anyone know of a supplier of MLS big bore exhaust gaskets for a rover v8?
Posted: Mon Feb 03, 2014 2:52 pm
by mgbv8
I use the twin composite ones and they have been fantastic ?
Does anyone do a MLS exhaust gasket for this?
Posted: Mon Feb 03, 2014 3:48 pm
by SimpleSimon
How about getting the faces trued up and running with no gaskets but with a smear of suitable high temp sealer? 8-)
Posted: Mon Feb 03, 2014 8:22 pm
by mgbv8
SimpleSimon wrote:How about getting the faces trued up and running with no gaskets but with a smear of suitable high temp sealer? 8-)
Yep!
A few folk I know do this. At least one of them just uses normal white bathroom silicone. If I were going to do this I would use high temp boiler flue joint sealer. I prefer the composite gaskets over the shiny dimpled ones as they will squish down a bit to take up the odd bit of a gap here and there. I do have to admit to being lazy and re using the ones on the car 5 or 6 times without keeping them in the right order :) The last time they came off two of them showed very tiny black streaks about 1mm wide where they had seeped a little.
Posted: Mon Feb 03, 2014 9:26 pm
As a general rule I don't like exhaust gaskets especially on a race engine. Get the faces properly flat then if you think it necessary use a thin wipe of bathroom silicon. I think the key here is get them flat!
best regards
Posted: Tue Feb 04, 2014 1:19 pm
by Quagmire
Just a point to bear in mind - doesnt silicone kill o2 sensors?
Posted: Tue Feb 04, 2014 7:32 pm
by mgbv8
It does. But we are talking about a smear on the faces. Having said that, all the guys I know who use the stuff dont have lambda sensors fitted.
Posted: Tue Feb 04, 2014 9:28 pm
:D
ah the joys of mechanical injection
Posted: Tue Feb 04, 2014 10:03 pm
by mgbv8
kiwicar wrote::D
For "mechanical injection" read "Dinosaur fuel delivery" :lol:
Posted: Wed Feb 05, 2014 7:20 am
mgbv8 wrote:
kiwicar wrote::D
beats a leaky bucket! :laser: :D
best regards
Posted: Wed Feb 05, 2014 9:03 am
by cammmy
Would a composite gasket help prevent heat from the exhaust from making it back into the head (especially if using exhaust wrap)?
Posted: Wed Feb 05, 2014 3:07 pm
yes but most of you have a water jacket to help out with that.
I'm not fussed because my exhaust is about 300c cooler than you petrol heads :D :D :D
best regards
