Single turbo on a V8?
Posted: Fri May 18, 2007 6:46 pm
by The Original Tom
I saw the set-up inquestion a while back on the net, no idea where, but the prospect intrigued me.
Someone was running one bank with a normal exhaust, and the other bank had a turbo manifold that ran a turbo (subaru I think?).
Surely giving the 2 sides of the engine completely different breathing characteristics promotes uneven wear and will produce some problems?
After the headers I don't know what the exhaust did, wether it merged to one or kept 2 separate pipes to the end.
What's the thinking behind such a set-up? That one bank fights off the turbo-lag, when the other one is winding the charger up?
Posted: Fri May 18, 2007 6:56 pm
No doubt far from perfect, but in a low boost situation, it should work ok.
Im pretty sure Saab did the same for a while with one if its V6 engines.
Posted: Fri May 18, 2007 10:02 pm
by Eliot
Had someone asking me about it a while ago, not sure where he's at with it at the moment - but seemed to want to go ahead with it.
http://mez.co.uk/forum/viewtopic.php?t=66
stevieturbo wrote:Im pretty sure Saab did the same for a while with one if its V6 engines.
Thats what i heard - but couldn't find the info.
Posted: Fri May 18, 2007 10:06 pm
I would just sort a link pipe, even if it appeared to be crap, and use the entire engine, and a bigger blower.
It would work much better
Posted: Fri May 18, 2007 10:32 pm
by bill shurvinton
It shouldn't work well, but that never stopped SAAB doing it on a V6 a few years ago.
Posted: Fri May 18, 2007 10:40 pm
Saab would have a little more time and money to develop it though, to make the most of it....
I still think a crude full single turbo would be better than a 1/2 turbo
Posted: Fri May 18, 2007 10:55 pm
by bill shurvinton
No doubt at all. But like me you believe that, if you are going to boost it, you might as well BOOST it.
Posted: Mon May 21, 2007 6:28 pm
by The Original Tom
Good to hear I'm not the only one that thought it odd...
