Zinc coated hubs or something?
Posted: Wed Nov 27, 2013 9:31 am
by chodjinn
Hi, I've got these custom hubs for the MGB but they're a little rusty, nothing a quick sandblast wouldn't sort out before new bearings & I refit them, problem is they'll only go rusty again, is there anything I can do to prevent this? Some kind of zinc coating etc or will that just come off? I'm obviously worried about the bearing surfaces being left as well.
If not no worries not the end of the world!
Posted: Wed Nov 27, 2013 6:19 pm
Get them blasted and powder coated ?
obviously protect any surfaces that you dont want coated.
Zinc/galvanising is an option if you can find somewhere to do it
Posted: Thu Nov 28, 2013 5:18 pm
by topcatcustom
Paint the exposed areas and lightly grease or spray something temporary on the bearing surfaces.
Posted: Sat Nov 30, 2013 5:23 am
by unstable load
Powder coating should do it OK. Mask the areas that you don't want done and then a light grease coating to protect the exposed bits afterwards.
Posted: Mon Dec 02, 2013 9:24 am
by chodjinn
If I was to paint it myself what paint should I use?
Posted: Mon Dec 02, 2013 11:04 am
chodjinn wrote:If I was to paint it myself what paint should I use?
A decent chassis black will last for ages. Use an acid etch primer first.
Posted: Tue Dec 10, 2013 1:07 pm
by chodjinn
DaveEFI wrote:chodjinn wrote:If I was to paint it myself what paint should I use?
Could you recommend a decent spray chassis black, or is it better to use something like brush-on; POR15 etc? Not had any experience with that as yet but I have a lot to do (entire front & rear ends)
Posted: Tue Dec 10, 2013 1:24 pm
Think a chassis black is too thick by nature to be sprayed. You could dip smaller items, I suppose. It's a bit of a dichotomy - finding something that works well as opposed to looking perfect.
Posted: Tue Dec 10, 2013 3:38 pm
by chodjinn
ok brush on is fine I'm not fussy, recommendations?
Posted: Tue Dec 10, 2013 4:26 pm
Ages since I bought any - it just came from my local car paint supplier.
Posted: Wed Dec 11, 2013 8:50 am
by chodjinn
No worries, I've just found an old thread from a while back where I've had almost exactly the same conversation ...... My memory sucks!
