Enigne conversion help
Posted: Mon Aug 05, 2013 6:42 pm
by Chicken Drumstick
Hi. Recently the 3.5 in my TR7 expired. It's looking like an oil pump of some kind. Anyhow I've bought a 3.9 off eBay to replace it.
Started stripping it down and I hadn't noticed until now that the 3.9 is a serpentine not a Vee belt.
I don't need the PAS pump or air con compressor. Is it possible to retain the serpentine belt and get rid of these or replace them with idle years of some kind?
I also have an offy manifold I want to retain. On the 3.5 it had a water pipe out of the back of the water pump. The 3.9 doesn't have this. Any ideas what I need to do in order to use this manifold with the 3.9.
Last up. The 3.9 came with an autobox and torque converter. Should I ha e any issues swapping on the flywheel from the 3.5? It needs to mate to an Lt77.
Same with the sump pan. Can I swap them over? The 3.9 one is longer and looks to foul the TR subframe.
Thanks.
Posted: Tue Aug 06, 2013 1:34 pm
by Muscle-Manta
You can retain the serp set up without the pas and air con pumps. JE sells an alternator bracket to replace the Land Rover one. It's much smaller.
Change the thermostat cover on your inlet manifold for one without the bypass and you won't have to worry about the lack of an outlet on your serp timing cover.
Posted: Tue Aug 06, 2013 2:32 pm
Thanks.
You don't have any links to any of these bits do you? Ta.
Posted: Tue Aug 06, 2013 2:53 pm
by Muscle-Manta
Bottom of this page for the alternator bracket.
http://www.johnealesroverv8.co.uk/9.html
Look out for a Rover SD1 thermostat cover they didn't have the bypass pipe.
