SD1 LT77 onto 3.9
Posted: Thu Jan 10, 2013 12:40 pm
Hi Guys
I have a Disco 3.9 motor (from an auto) and an SD1 LT77 Gearbox, flywheel etc.
Will the SD1 bits mate up to the 3.9 okay? I've read on here about differences between the SD1 and 3.9 setups but it seems to relate mostly to the flywheel and clutch.
Second question is. The 3.9 is going to be a hot motor and I've heard that the 3.9 manual had a larger clutch than the SD1? If I source a 3.9 flywheel and clutch gear, will it mate okay with the SD1 gearbox? Would it be worth doing this?
I know that there are better boxes to use but I have two LT77's and will be reconditioning one to use with this motor as I'm unlikely to be able to afford something stronger (My brother is an engineer and ex-gearbox mechanic who can help with the labour). I'm hoping that by not being a silly bugger the box will last okay.
Cam
Cam
