14CUX wiring Harness
Posted: Fri Dec 07, 2012 8:54 pm
by mikemgbv8
I'm loking for an engine wiring harness for a Rover V8 with 14CUX hotwire system, circa 1987 with Lambda sensors .
My MGB V8 had a bad fire some while back, I've managed to find a wiring harness on e-bay , but it does not have the Lambda sensor wiring, and the diagnostic plug is not right, I guess it's from an earlier car.
Does anyone here have a good source for old Rover V8 parts, who might have trhe harness please ?
Posted: Fri Dec 07, 2012 9:28 pm
by bodger
if you have an early one its easy to add the wiring the places are there on the connector , just follow the diagram on here and add the bits that are missing on yours
..if you have the correct ECU them no probs
Posted: Fri Dec 07, 2012 11:27 pm
by mikemgbv8
Hi Bodger.
I did think about canibalising my old harness for the Lambda wiring, can I buy the connectors for the ECU socket fitting somewhere ?
Posted: Sat Dec 08, 2012 1:12 pm
by bodger
Posted: Sat Dec 08, 2012 1:31 pm
by mikemgbv8
Thanks Bodger,
That looks like the right route
Posted: Sat Dec 08, 2012 3:30 pm
by bodger
..no probs
Posted: Sat Dec 08, 2012 5:27 pm
by richardpope50
I have swapped from 14CUX to MegaSquirt and so have a pulled apart harness including the lambda sensor connections, diagnostic socket, Cat / non-cat resistors, etc. Will this help?
Posted: Sun Dec 09, 2012 11:44 am
by mikemgbv8
Hi Richard, thanks for the kind offer, Perry on the MGV8 forum said you guys would be helpful.
I'm going to try Bodgers suggestion and strip out the old wires, and buy new connectors, seems a pity to destroy you old loom when I can probably "bodge" mine.
I will be back with the results shortly.
Posted: Sun Dec 09, 2012 2:50 pm
by bodger
remember its only a
bodge is it DOSN'T work ..
Posted: Sun Dec 09, 2012 4:08 pm
by richardpope50
mikemgbv8 wrote: seems a pity to destroy you old loom when I can probably "bodge" mine.
My loom is all taken apart and wires cut so it is a bin job anyway. I thus have the ECU plug with wires where some / most are short and have been cut. The lambda sensor connectors are thus in effect off the loom. I have both the LR sensors too as I've now gone wideband.
You could join the wires into your loom by soldering together and covering in heatshrink.
Posted: Sun Dec 09, 2012 11:48 pm
by mikemgbv8
Hi Richard,
I've just pulled my old harness apart, and it's a bit sad looking, so I will take you up on your kind offer if I may.
Are the Lambda sensors still attached to the blue screened wire ?
Are they handed, I noticed the wire on pin 23 has a white sleeve on it to distinguish it from the one on pin 24 ?
The wires to the diagnostic plug seem different from the wiring diagram , the harness plug which connects to the reader has the same colours as the diagnostic , ie brown, black/grey, pink and brown/pink, but at the ECU end it's white/lt green pin 9, white/pink pin18, blue/grey pin 27, and white yellow pin 37.
looks like I'm going tohave to follow the wire back and see wher they change colours.
If you can let me know how much you want for the lambdas and blue screened wires, and the diagnostic plug and associated wires , I'll arrange to send funds to you.
Thganks once again
Posted: Wed Dec 12, 2012 3:19 pm
by mikemgbv8
Hi there,
Yet another set back, the connectors I bought from Polevolt turn out to be the wrong ones, evidently the do not stock 14CUX connectors, I'm goint to have to look elsewhere.
Bodging's neve simple is it !
Posted: Wed Dec 12, 2012 5:42 pm
by richardpope50
mikemgbv8 wrote:If you can let me know
Did you get my PM? Please PM me your e-mail address.
