Detent valve stuck on GM180
Posted: Sun Jul 29, 2012 2:00 pm
Hi there V8-friends,
When replacing my kickdown-cable for a new one I noticed that the detent valve is stuck, no movement at all! It is the axle with the hole in it where you attach your kickdown-cable in. That explaines why it wouldn't shift to 2nd. The car had not moved for a year or 8 (longrunning project
I'm afraid this can only be fixed by opening the transmission? But I don't think I can reach it when removing the sump as it is placed on the upper side of the transmission.
Anyone with a solution or tips?
Thanks Jasper from Maassluis/The Netherlands
