LT77 oil & Quantity??
Posted: Fri Mar 09, 2012 10:17 pm
Hi guys, I know this has been discussed many times over the years, but I would like to get some suggestions.....
I know Rover changed from EP90 (IIRC?) to an ATF oil as a result of difficult gear changes when cold, and there have apparently been some issues with using ATF if the box is going to be used hard..... also seen people mention the use of Mobil 1 0w-40 fully synthetic (or synthetic of similar weight)!
basically the box is going to get a little bit of a kicking as I'm going to be drifting, mainly using 2nd & 3rd gear..... so what would you recommend and what quantity do the LT77 take, Think I read some where it was 1.5L???
Jono
Jono
