Suction from rocker top?
Posted: Sun Jan 15, 2012 8:18 pm
by auction1st
Hi all, I have an 86 efi engine fitted with twin su's. I've renewed all the ignition system but she is not firing on 5 and 8 all of a sudden! Theres a spark on all 8 plugs timing is correct but no joy until you rev hard. Today whilst trying to find the problem I took the oil filler cap out whilst she was running and the revs dropped write off and there is a dedefinate suction preasure. This is obviously some sort of induction leak but I am open to suggestions from where? I fitted new head gaskets etc before I put the engine in the landrover but haven't managed to get it running spot on yet so all help will be welcome
[/b][/i]
Posted: Sun Jan 15, 2012 8:31 pm
by RoverP6B
Which rocker covers have you fitted and how have you set up the engine breathers?
How have you linked the SU cabs into the breather system?
Without proper crankcase ventilation which to me sounds the problem, your engine will never run properly.
Ron.
Posted: Sun Jan 15, 2012 9:14 pm
by auction1st
Hi Ron I think they are old P6 covers linked to the SU's through what apears to be a filter. The problem is I bought it as a non runner project which was in bits! Have you any idea why 5 and 8 are the only two that don't fire?
Posted: Sun Jan 15, 2012 11:16 pm
by ian.stewart
change the plugs, For some strange reason, if you manage to wet Rover plugs they never seem to work well again, I always had a spare set in the glovebox in my cortina.
Posted: Mon Jan 16, 2012 7:11 am
by RoverP6B
There needs to be two flame traps, once for each carburettor with the hoses running from each rocker cover.
Is there a breather pipe with filter running into the rear of the lifter gallery?
Ron.
Posted: Mon Jan 16, 2012 12:54 pm
by auction1st
There is the two as described one to each carb but no other breathers fitted that I can see!
Posted: Mon Jan 16, 2012 1:11 pm
You could try disconnecting the breathers and plugging the carb ports to see if it runs any better.
Posted: Mon Jan 16, 2012 7:15 pm
by DEVONMAN
Plug leads 5 & 8 are directly opposite on the dizzy cap.
Are you sure the leads are in the correct position in the dizzy cap.
If 5 & 8 are reversed, the plug will fire on the exhaust stroke on both.
Grasping at straws
Denis
Posted: Mon Jan 16, 2012 8:00 pm
by RoverP6B
The breather off the lifter gallery is important as air will be drawn in at this point. The exit is via the flame traps into the carburettors.
Ron.
Posted: Mon Jan 16, 2012 9:10 pm
by auction1st
Thanks for that Denis but all leads are right and it has run on all 8 since the build? After reading through a few other threads 5 and 8 are fed from the same carb! Tied with this induction problem I m going to have another try this weekend at disconecting the breathers and setting the carbs up again, unless sombody has a better idea?
Posted: Tue Jan 17, 2012 6:30 am
by RoverP6B
auction1st wrote,...
Unless your engine has a proper crankcase ventilation system in place, attempting to tune your carbs will be a waste of time. The engine will never run properly, crankcase pressure will increase and oil will start to leak from all the seals.
Ron.
Posted: Tue Jan 17, 2012 8:44 am
by DEVONMAN
Going back to your first post ,you said it's an EFI engine running on carbs.
The early carb engines normally have an air inlet to the crankcase at the rear of the valley area and this hole would be plugged on an EFI block. So, besides the breather pipes fitted to the su's, you also need a small inlet with a small filter on it. Otherwise you will be sucking air from the block and the crankcase pressure may become excessively negative and there will not be propper ventilation.
Another point to check is the dashpot piston in the carb feeding 5 & 8.
If this is stuck down then again the suction in the breather pipe will increase and half the engine will not run properly including 5 & 8.
Denis
Posted: Sat Jan 21, 2012 8:38 pm
by auction1st
Thanks everybody I ve fitted a secondry breather to relieve the negative preasure in the crankcase as sugested
When I came to set the carbs up I realised the r/h carb was drawing a lot more air than the other side, I've blanked the breather off and she ran on all 8!!! Sunday job is to strip the carb and find the problem happy day, thanks for the help.
