rv8 water pump
Posted: Thu May 19, 2011 8:16 pm
by shawser
what are the two stub pipes that come out the back of the water pump, one is open and one is closed, what does the open one do?
Posted: Thu May 19, 2011 8:44 pm
They are both returns, as you say, one is blanked off on some variations.
One is the thermostat bypass (short pipe from inlet manifold), the other is heater return (long pipe that runs under the inlet manifold that emerges under the heater outlet at the rear of the manifold).
I presume you don't need the heater return.
I can't quite recall the configuration that has that stub blanked off.
rv8 water pump
Posted: Thu May 19, 2011 9:15 pm
by shawser
when i bought my hilux with rv8 engine, the long pipe was connected to the open stub pipe, i blanked the stub off and connected the long pipe to the short metal pipe coming off of thermostat housing, my truck wouldnt circulate the water today after putting it back together, could that be the reason why?
Posted: Fri May 20, 2011 7:03 am
Could well be. What inlet manifold is it?
On the standard Range Rover one (as I recall), there should be the long pipe running under the manifold that connects to one of the stubs, and a stub underneath the thermostat housing that connects to the other stub. Do you not have both?
rv8 water pump
Posted: Fri May 20, 2011 9:13 am
by shawser
it has the offenhauser 360, the long pipe was just connected to the left hand stub on pump as you look down on it, nothing on right hand side
Posted: Fri May 20, 2011 9:23 am
by ramon alban
I'm not sure I can visualise your actual arrangement but in general the principle is to ensure that the coolant can circulate thro the engine and heater matrix BEFORE the thermostat opens.
This prevents hot spots and allows for cabin heating during that period.
The thing is better explained, in context, on page 2 of the PDF available from here
http://www.vintagemodelairplane.com/pag ... ing01.html
If you actually needed the second outlet, is it possible to drill out the blanked off pipe?
rv8 water pump
Posted: Fri May 20, 2011 12:00 pm
by shawser
cheers for info. Did you see on ignition forum that i got my rv8 going? timing was out 180.
