Chimaera cooling problem
pawmaro
Post by pawmaro »
Hi my 4.0 TVR struggles to get above 70 degrees driving. Can get to about 75 idling.
I have fitted a new 82 thermostat but not helped.
When running at 70 irregular tickover and dies
When I get temp up to 75 ish ticks over 850 rpm fine.
I also changed temp sensor which has improved running.
I used to run 3500 rover sdis in 80's and used to run 88 degree thermostats to get them running nice.
Anyone fitted 88 degree thermostats to their tvr?
thanks
Paul
Return to “Cooling Area”
