Servo vacuumed INFO
Posted: Fri Mar 03, 2017 1:55 pm
by redm6gtr
Does anybody no how much vacuumed is produced by the V8
I think I need to fit a 12volt vacuume pump to improve the brake servo/master cars braking
Thanks for any advise
fordpop52@aol.com
Posted: Fri Mar 03, 2017 2:29 pm
Pretty well all production vehicles fitted with the RV8 managed with a vacuum brake servo run from the inlet manifold.
Posted: Fri Mar 03, 2017 4:33 pm
by Blown v8
I used to run with twin servos,with a high lift cam on a blown rv8 with no problems
Re: Servo vacuumed INFO
Posted: Fri Mar 03, 2017 11:19 pm
redm6gtr wrote:Does anybody no how much vacuumed is produced by the V8
fordpop52@aol.com
That very much depends on the engine.
But I can see very few applications needing an electric pump.
Posted: Fri Mar 03, 2017 11:33 pm
by garrycol
If you are having problems you then need to look at the plumbing to the booster (do you have it off the right takeoff - the pipe/outlet is about 10mm in size) or you have a booster problem.
If the problem persists you could always put in an alternator from a TDI or TD5 which has a inbuilt vacuum pump.
But there is no issues in an RV8 providing enough vacuum
Garry
Posted: Sat Mar 04, 2017 9:08 pm
fordpop52@aol.com
A Rover V8 in good condition (like pretty much all petrol engines) will pull an almost total vacuum under overrun conditions.
Rover V8 brake issue
Posted: Sat Mar 04, 2017 10:49 pm
by redm6gtr
Guys
The rover is fitted with a fast road cam the inlet is an Offernhouser fitted with a pair 45 Weber carbs also a Mallory dist
The brakes were a 7 inch servo with a mark 2 jaguar master
They both needed replacing so I fitted a new servo with a 1 inch bore master
A mistake it should have been a 7/8 bore
There is a one way in the servo pipe
So now I have another master on order and will fit a 12 volt power servo pump from a BMW/VW for extra vacuum
So we will see how it goes
Posted: Sun Mar 05, 2017 12:15 am
are you sure your existing servo is fitted/adjusted correctly and actually holds vacuum ?
Whatever level of vacuum that may be
Posted: Sun Mar 05, 2017 4:52 am
by unstable load
I'm with stevieturbo here... are you sure the Booster is good? You shouldn't need additional gubbins if it is all good.
The only difference a bigger master cylinder has is more pressure required on the pedal, boost is not affected by the M/C.
Servo
Posted: Sun Mar 05, 2017 9:11 am
by redm6gtr
Brand new servo just fitted
Posted: Sun Mar 05, 2017 2:56 pm
by mike-b
Others reading this may well know better but to raise a point - Would a leaking inlet manifold not play a part of the problem, or even be it?
Posted: Sun Mar 05, 2017 7:06 pm
You could measure the vacuum........
Posted: Mon Mar 06, 2017 9:18 am
mike-b wrote:Others reading this may well know better but to raise a point - Would a leaking inlet manifold not play a part of the problem, or even be it?
I'd have thought you'd notice that by poor engine performance before the brakes?
Posted: Mon Mar 06, 2017 2:20 pm
DaveEFI wrote:mike-b wrote:Others reading this may well know better but to raise a point - Would a leaking inlet manifold not play a part of the problem, or even be it?
Possibly...but I dont think there has been a proper explanation of what is even wrong with the brakes ?
Posted: Mon Mar 06, 2017 10:37 pm
by garrycol
Yes - is the booster connected to a small bleed port in the manifold or a proper large bore bore specifically the size for a booster? Also the brakes seem to be a mish mash of components that may not be compatible with each other.
I doubt a vaccum pump will fix the issue if the same size plumbing as is in place now is used.
The RV8 develops plenty of vacuum - as evidenced by the hundreds of thousands of setups around the world that are working fine - so there is something wrong with the OPs set up not the vacuum.
garry
