Drop knuckles / Front ARB / Suspension for track/race R32
Posted: Fri Nov 20, 2015 1:02 pm
I have a '91 R32 Skyline GTS which I am building for track/race use. Not road legal.
It is getting a lightweight all-alloy V8 (1UZFE) and has a Macpherson strut conversion at the front.
The front setup is currently coilovers, extended lower arms/tension rods with Tein steering rods, and a set of Driftworks Geomasters to give me -50mm drop.
I have an adjustable ARB to go on there as well.
I have an opportunity to buy a full Wisefab front kit. I realize this is drift orientated, but it has -60mm drop spindles and a significant weight reduction in unsprung mass (which is what I am mainly interested in)
The problem/question is, you cannot run a front ARB with this setup. Now, with the drop provided by the drop spindles there is less need to run increased stiffness at the front. And combined with the lighter engine I have, I was wondering if I could get away without running an ARB, or is this just not a good idea for an entirely track orientated car. I can obviously fit higher rate springs to the coilies if that would help.
