lexan support
Posted: Tue Feb 23, 2010 8:33 pm
by bones
Hi all, would i need a centre support on the rear window of a rover sd1 to stop the lexan from bouncing or sinking in the middle. If i do need one will a strip of alloy be ok straight down the middle??
rich
Posted: Tue Feb 23, 2010 8:59 pm
by Ian Anderson
Take your lexan (oversize)
Lay it on top of your rear screen and heat it wilt a hot ait gin until it takes the shape of the rear screen
Let it cool and trim the edges to fit
Screw into place - the external curve should not be able to "cave in" - works for GT40's above hot engines
Posted: Tue Feb 23, 2010 9:19 pm
by bones
my window has already been cut to size so i can use the original rubbers and metal surround,
rich
Posted: Mon Mar 08, 2010 3:41 am
by Robrover
I have perspex in my SD1 rear screen 3mm thick by memory.
I change the screen every 3 years or so due to scratching. The current screen is holding its shape ok (flat), but the previous one started caving in around the centre so I fitted two T-section lengths of aluminium rod underneath to hold it up (on the inside of the screen not outside NASCAR style).
Posted: Mon Mar 08, 2010 3:42 am
by Robrover
And yes, I use the original rubber seal and chrome filler strips.
Posted: Mon Mar 08, 2010 10:53 am
by bones
cheers for the reply, i will fit the support bars for it then, thanks again
rich
