Page 2 of 3
Posted: Mon Jul 20, 2009 9:44 am
by kev_the_mole
Rich,
sorry for the delay but been away at family wedding and my laptop was forbidden. Carriage for half sheet is £9, carriage for whole sheet (nearly 30kgs) would be around £15.
Hope this helps.
Posted: Tue Jul 21, 2009 6:52 pm
by bones
carriage is ok, will be using it on the escort know. I will measure up to see how much i need, thanks Ian
rich
Posted: Tue Jul 21, 2009 9:40 pm
by Paul B
kev_the_mole wrote:Rich,
Hope this helps.
Is it these people you work for? I've been thinking of using polycarb for the windows in my hot rod, simply because it is lighter and easier to work with than glass, plus I'll be using old fashioned type sliding side windows and worry about them cracking when slamming the doors. And I'll need to glue little finger grips to them to move them.
http://www.theplasticshop.co.uk
Posted: Tue Jul 21, 2009 10:08 pm
by kev_the_mole
Posted: Fri Jul 24, 2009 8:35 am
by Robrover
I've got 3mm Acrylic(Perspex) in the f/g rear hatch on my SD1. Replace it every five years or so due to scratching, sun damage, but it's cheap enough at less than AUD100 [UKP49] and easy to fit.
Posted: Sat Jul 25, 2009 6:54 pm
by Paul B
Ahh, all becomes clear. (No pun intended)
What is the score with cutting this stuff, can I do it at home easily enough? I'll be needing a bunch of shapes, not all regular square sizes, so I'd need to do trimming and rounding etc.
Posted: Sat Jul 25, 2009 10:23 pm
by kev_the_mole
You can saw it with a jigsaw but to get a good finish on the edges you either need very high speed diamond router cutters or get the edges flame polished.
Posted: Wed Jan 27, 2010 9:36 pm
by JJMclure
sorry to reanimate an old thread but can you use flat sheet and fit it to a curved door frame or does it have to be shaped to fit the door? Also is it legal in a road car?
Posted: Thu Jan 28, 2010 7:16 am
by bones
JJ ,im using it on my road car, a rover sd1. if you go to the post on pre-cut lexan the company web site is there and they do all makes of cars.
rich
Posted: Thu May 24, 2012 11:54 am
by bilobarber
I recently purchased 'Maqargarita XL', (giant Margarita glass production). I must say, it's the best purchase that I've made in a long time. The production of the giant Margarita glass is incredible! You can check out at
Posted: Thu May 24, 2012 1:43 pm
by JSF55
Spammer?
Posted: Sat May 26, 2012 6:42 am
by unstable load
Spammer?
First post and such high quality, weapons grade bullshit, I'd agree with you 100%.
Posted: Tue Jul 10, 2012 8:33 am
by cammmy
Just wondering, could you tint the rear panel using film? The tint would protect the perspex (if UV protective) and if you put it on the outside it would protect from scratching? Just replace the tint every few years instead of the whole window
Robrover wrote:I've got 3mm Acrylic(Perspex) in the f/g rear hatch on my SD1. Replace it every five years or so due to scratching, sun damage, but it's cheap enough at less than AUD100 [UKP49] and easy to fit.
Posted: Wed Jul 11, 2012 9:00 am
by Robrover
Possibly you could make it last longer, but not here where the sun's the big killer.
I have now upgraded to lexan margard which is more scratch resistant than perspex, but no heavier. It claims to combine the impact strength of Lexan polycarbonate sheet with a proprietary abrasion and UV-resistant Margard coated surface which is warranted against yellowing, breakage, coating failure and loss of light transmission and offers improved resistance to weathering.
Posted: Sat Aug 31, 2013 10:37 pm
by Markus
Hi Robrover.
Just wondered where you sourced the Margard from?
Cheers!
