The build begins... 1932 Ford 4.6 Rv8
Hot rod Ed 32
Post by Hot rod Ed 32 » Tue Jun 05, 2018 1:36 pm
Just a quick ask! Do you think an inlet with su carbs will be ok on 4.6 Rv8
harvey
Re: The build begins... 1932 Ford 4.6 Rv8
Post by harvey » Tue Jun 05, 2018 3:55 pm
I know people that have done that and not had any problems. It won't give the ultimate in performance but if you're not looking for that it will be fine. Just use an HIF manifold and carbs.
Post by ChrisJC » Wed Jun 06, 2018 7:16 pm
I found that 1.75" SU's were a bit small at full chat. I switched to 2" SU's and ported the manifold.
caprinerd
Post by caprinerd » Wed Jun 27, 2018 6:19 pm
im now running a 4.6 on 2" su`s got mine from a jag not set up as yet but a lot better
