Page 4 of 5
Posted: Sun Jan 17, 2010 3:42 pm
by NorthernBloke
I'm going to be putting the Mk1 back on the road shortly and one of the pre reqs is, of course, oil and filter change and after reading through this thread, and especially the last page with Andrew disection, I would like to give your filter a go
Have you sussed out the paypal link yet as that would be easiest.
Posted: Sun Jan 17, 2010 6:34 pm
by slice
Have you sussed out the paypal link yet as that would be easiest.[/quote]
Hello Andy
thanks for your interest in my filters!
the Paypal arrangement cocked up somewhere when i was setting it up - seems as though its gone wrong at my bank.
I'm going to the bank tomorrow morning to try and resolve the issue.
will be back to you tomorrow nite
thanks again
dave
Posted: Mon Jan 18, 2010 8:41 pm
by andyv8van
Will also order one of your filters when you get the Paypal sorted.
Ill be Ready for the show season then..........
regards
Andy
Posted: Mon Jan 18, 2010 9:44 pm
by slice
Hi Andy, Andy
i dont know much bout bank accounts 'n stuff...seems it was me that cocked things up!! - but, must say the guys at Abbey were very helpful!
Can't fix the problem straight away though - it might take up to a week to sort out.
will let you know the moment its sorted and paypal is working
thanks again guys for your interest
cheers dave
Posted: Tue Jan 19, 2010 8:41 pm
by NorthernBloke
No bother Dave, I'll keep an eye on the thread
Posted: Wed Jan 20, 2010 8:23 pm
by andyv8van
NorthernBloke wrote:No bother Dave, I'll keep an eye on the thread
me too
Andy
FINALLY.....
Posted: Sat Feb 06, 2010 2:56 pm
by slice
Hello again Andy, Andy
the account is finally sorted and my site has been updated to accept paypal.
Plent of filters in stock for whenever you're ready
thanks
dave
Posted: Sat Feb 06, 2010 6:49 pm
by NorthernBloke
Nice one Dave, just ordered mine - gone back up to £20 + p&p, is that correct?
Posted: Sat Feb 06, 2010 7:32 pm
by andyv8van
have put an order in for mine
regards
Andy
ONE SIZE FITS ALL
Posted: Sun Feb 14, 2010 7:57 pm
by slice
Been busy with an investigation - finding out what other V8's my filter fits.
pleased to announce that it fits ALL Ford V8's and ALL Chrysler V8's.
Also discovered that 99% of the "remote mounted" filter heads also have the same threads (3/4 - 16 UNF)
Its a far more popular thread than i imagined.
So... if you're interested in upgrading pls send me a msg with your existing filter number and i will check it out for you
thanks
dave
Posted: Sun Feb 14, 2010 8:14 pm
by Coops
i would if you did a shorter filter
Posted: Sat May 01, 2010 2:55 pm
by Muscle-Manta
Dave, I have ordered one of your filters. How many miles do you recommend between filter changes? Would every other oil change @ 5000 mile intervals be sufficient?
filter change frequency
Posted: Sat May 01, 2010 5:52 pm
by slice
hello Paul thanks for the order!
how many miles do you generally travel per month and is it good steady runs or stop start heavy traffic?
the reason i ask is because if you are on long runs then less carbon is being generated and finding its way into your engine oil.
My filter does remove this carbon (as well as all the harmful solid contamination) from oil circulation but this will naturally reduce the service life of the filter to a degree.
as an example i travel some 1500 miles per month on good runs with very little idling.
With the present filter i have done 15,000 miles (same oil & same filter) and the oil is still spotless! (i test it regularly to check that there isl no solid contamination in circulation) however i have decided i will change it next weekend because i begin to be concerned about natural depletion of the oil anti-wear and anti-oxidation additives.
so... it seems you don't travel long distances then a filter change at every other oil change sounds a good option.
if you have any other questions then dont hesitate to shout
thanks
dave
Posted: Sat May 01, 2010 6:27 pm
by Muscle-Manta
Hi Dave, As the car is only used for fun I plan to avoid traffic and long periods of idling if possible.
I don't comute in the car and cover no more than 5000 miles a year.
Paul.
Posted: Sun May 02, 2010 11:30 am
by slice
hi Paul,
yeah i think that the 5000 mile annual filter change would work well for you then.
one thing you will notice once the filter is installed is that the oil won't go black as it normally does - it will stay much clearer...and only become an amber brown by the time you come to change it in a years time.
this is simply due to the higher efficiency glassfibre media
the filter will be on its way to you tuesday morning
thanks again
dave
