Posted: Fri Jun 21, 2013 10:14 pm
I didnt lift off on purpose Stevie. I had lashed the nitrous to a button in my left hand. So i was holding the shifter with two fingers and as the gas hit the car shifted to the right and as I corrected the steering i let the button go by mistake. I'm happy with the small amount of air under the front tyre now. It used to lift the front left about 8" with the other one about 2" off the deck. Now it seems to stick to the ground a bit better with the rear suspension strapped down a bit better. I've found the sweet spot with the tyre for the time being at 12psi cold.stevieturbo wrote:Was it really worth lifting off the gas ? Looked like you could have held it on just fine ? Was only one wheel after all...although maybe feels a lot more inside the car ?
And what tyre pressures ? When I used mine, my tyres looked almost flat ( although guess they were at near 10psi lol )
Although TBH, not really sure tyre pressures made a huge difference. Had tried various from 10-25psi ( hot )
Although usually ran in the 12-15psi range.
Next time out I'll do a burnout and then get jason to quickly check tyre pressures to see if they have gone up at all?
I did try then down at 10psi and 9psi and they seemed to hook up ok. But i found the car wandered from the back end at high speed near the finsish line. It just felt like badly worn steering?
Perry
