3.5 rover v8 head bolt
Looking for that special part?
paulmanta
Post by paulmanta »
I have an early 14 bolt per head 3.5 I am rebuilding and I need one medium head bolt.
It's got a 5/8 head, it's 3 inches long and the washer is separate. Letters G, K and N on the head.
Somehow I am one short! Care was taken and it was all put in a safe place but life had other plans.
I do however have an extra short bolt. So I'm wondering if someone put it together wrong a long time ago.
Has anyone got a suitable bolt they could send me? Happy to pay.
Thanks.
Paul
Re: 3.5 rover v8 head bolt
I'm sure I have Paul - I just need to remember to check tomorrow.
paulmanta
Post by paulmanta »
Hi Chris, if you have you will be a great help, I'm stuck on this now and I still have a few other little gremlins to iron out but I need this head on and torqued down.
I am convinced that this had the short bolt in it when I stripped the engine down to freshen it up.
How the threads were OK I have no idea, especially since it had to be in one of the higher torque locations but it all checks out.
My guess is that it was a mistake in the head bolt set the previous owner used and he didn't notice.
Mind you when I went through the timing of the cam I found that that was out too, it's an aftermarket cam and original gear set. I put an adjustable cam wheel in and now it's where it should be.
Keep In touch, I will pm you my number.
Paul
paulmanta
Post by paulmanta »
Chris has sorted me out and it's all fitted and done tonight.
Top bloke!
Cliff4WD
Post by Cliff4WD »
Are these bolts ok to reuse or should new ones be fitted?
Cliff4WD wrote:
Fri Jul 31, 2020 11:28 pm
The BL manual says to check them for stretch against a new one. If the same, OK to re-use.
Cliff4WD
Post by Cliff4WD »
:shock: so I have to buy new bolts to measure and check if the old ones are still good.:lol:
Return to “Wanted”
