Re:
Post by Coops » Fri Jan 05, 2018 9:45 pm
Rossco wrote:
Tue Aug 01, 2017 11:49 am
Latest pictures of the Procharger
will soon be in my grasp :twisted: :twisted: :twisted: :twisted: :twisted:
Rotrex C38-91 supercharger and Cossie RS500 Intercooler @ 14psi of Boost. 404 RWHP, (4.6)
New Forged 4.8 V8 kitted out with the dogs Cajones of parts and a procharger D1SC. 2017 :D
Post by Coops » Sun Jan 14, 2018 8:29 pm
A few of the hydraulic clutch conversion
Rossco
Moderator Gold
Moderator Gold
Post by Rossco » Sat Mar 24, 2018 6:00 pm
Well the mounting bracket is now done except for the polishing which I'll try to get done next weekend.
The number one driver for the design has been the almost infinite variation of Rover/Buick setups, therefore setting the pulley alignment is done mainly with the three mounting tubes at the rear. These can be made to any length.
Next up is the belt length, again there's so many variations I decided to give the idler pully a total of six predefined mounting positions. In fact just by drilling and tapping a 3/8 UNC hole the idler could be mounted anywhere that it will fit. It's even possible to fit two idlers if needed.
Last night I modelled the whole thing in Fusion 360 so if there's a next time I can use the CNC router rather than the mill.
The pictures below are obviously without any of the other ancillaries or a belt tensioner.
Install on the car should be in the next 3-4 weeks so once its been on the dyno we'll come back with the results.
F Type......the new BL Allegro
Post by stevieturbo » Sat Mar 24, 2018 11:02 pm
I would drop that idler a bit to allow room for a good strong spring tensioner on the top side....and the belt will stretch and move quite a bit in use.
Post by SuperV8 » Fri Apr 06, 2018 9:57 am
How are you driving the alternator and water pump?
Post by Coops » Fri Apr 06, 2018 3:22 pm
one belt driving it all as per my current rotrex set up
Post by Coops » Mon Apr 09, 2018 5:52 pm
A couple of little hiccups we are having with the car at the moment lol,
won't idle correctly and we think we have pin pointed it down to a faulty TPS sensor,
And good ole rover no longer make the tps :lol:
So
Have a 4.6 plenum on its way to see if we can just bolt that on and use the later type tps and hopefully breather hoses etc etc are all in the same place as the hotwire plenum,
IF not the next option is to remove the throttle spindle from the 4.6 plenum and fit it to the plenum currently on the car that has all the hoses etc set up on it for the car and retro fit the later tps to that plenum,
watch this space .... :rofl
Post by DaveEFI » Tue Apr 10, 2018 8:36 am
Which TPS were you using originally? The large round black one as fitted to he flapper injection has been re-made, for a Jaguar specialist.
Post by SuperV8 » Tue Apr 10, 2018 11:09 am
The
So
The 4.6 plenum has a different IAC valve arrangement, I think better/neater as there are no hoses.
I'm using this with megasquirt, its a 4 wire.
Post by DaveEFI » Tue Apr 10, 2018 11:42 am
I've fitted a Bosch PWM idle valve to my SD1. Fits in place of the over-run valve, which isn't needed with MegaSquirt. Had to make an adaptor plate. Works better than the hotwire stepper motor one I was using before.
Post by Coops » Tue Apr 10, 2018 12:12 pm
Any pictures please guys?
I'm too doing away with the stepper motor 👍
Post by DaveEFI » Tue Apr 10, 2018 1:13 pm
Post by Coops » Wed Apr 11, 2018 7:02 am
Thanks mate.
I'm using a similar valve will get pics tonight
Post by SuperV8 » Wed Apr 11, 2018 11:21 am
4.6 plenum modified for front entry, using the later stepper motor. On the left hand side, just up from the hose clamp screw, the small black cylinder. That's the IAC valve, no hoses required.
Image2012-08-13195408 by t c, on Flickr
Post by SuperV8 » Wed Apr 11, 2018 11:24 am
And this is the 4.6 plenum before mods
Top hole is TPS
Bottom hole is IAC
Image2012-05-12135330 by t c, on Flickr
