0-60
paulsv8manta
0-60
Post by paulsv8manta »
Here's a question for you mathematicians.
The Rover sd1 3.5 weighs 1915 kg giving a 0 - 60 in 7.1 seconds.
If said engine is transplanted into a car weighing 1065 kg what would the 0 - 60 be?
Haha, a lot less!
I'm not sure you can calculate it with any degree of accuracy can you?
ged
Post by ged »
That weight is Gross laden, curb weight is approximately 1500 kg then add your weight.
Too many variables to calculate accurately but at a guess just over 5 seconds.
There's no doubt it can be calculated...but with so many variables, you'd need a lot more info, especially about traction available etc !
F=ma so assuming (big assumption) that force is constant
a= (mRover * aRover) / (mNewCar)
aRover=3.77 m/s^2 according to http://www.procato.com/convert/
1915* 3.77 / 1065 = 6.77 m/s^2
6.77m/s^2 = 0-60 in 3.96 seconds :D
plastic orange
Post by plastic orange »
Both my V8 Minors weigh around 1100kg. Rover 3.9 engined one with hurricane cam and edelbrock carb and inlet through a jag IRS and BW 65 box does a 14.7 quarter at 96 mph - around 200 flywheel hp. Probably equates to 0-60 in around 6 seconds. My other Minor with an LS1 5.7 litre with around 350 fwhp does the quarter in 12.2 @116 mph. GM 4l60e box and Ford 9 inch rear.
Both cars have a power sapping rear end - more so than an SD1 I'd say.
Pete
Image Image
kokkolanpoika
Re: 0-60
Post by kokkolanpoika »
My 418hp SD1 run 7 years old road tyres witch are like stones. 2.7s/60ft and 112mph 13.9s 1/4 mile.
6.4s to 0-82.5mph. It will weight with driver and full tank 1700kg.
So 0-60mph would be under 5s. G-tech say 4.6s..
My 2800kg Range Rover sport 4.2SC make 0-71.2mph just in 6.4s. 1/4mile 15.3s and 92.5mph. 60ft 2.3s every time.
It is near as fast as Suprcharged corvette with semi slicks 0-60mph. Couple of tenth second slower.
Timo
Re: 0-60
My GT40 was1140kg at SVA and I added soundproofing and bits since then so 1200?
https://www.gt40s.com/threads/santa-pod ... 74&slide=3
Shows a trip I did to Santa Pod and my timing sheet
Lots of wheelspin on street tyres, no special preparation drove it there and back, even had tools and my lunch /water on board!
Dino says 250 ish HP out of the 3.9, at the flywheel, and transaxle soaked up about60 of those!
Re: 0-60
paulsv8manta wrote:
Sun Dec 17, 2017 8:45 pm
The figure you've given for the SD1 is the gross vehicle weight. Showroom weight is quoted as 1440 max. That 7.1 O-60 won't be achieved with the car fully loaded.
Return to “General Chat Area”
