spider plate ??
General Chat About Nitrous Oxide.
Post by mgbv8 » Mon Jan 10, 2011 9:16 am
Getting excited now :)
All systerms tested and working as of yeasterday. Thats it now. I'm working until Saturday afternoon so no more real tinker time :(
Please be dry for a few hours on Sunday morning. I just want a couple of attempts on fresh glue !!
bones
Post by bones » Tue Jan 11, 2011 8:34 am
Goodluck for sunday Pel. Hope it all goes ok :D rich
Post by mgbv8 » Tue Jan 11, 2011 8:38 pm
I'll running my old fogger setup this weekend Bones ????
Still need more work on the spider I reckon..
bones
Post by bones » Thu Jan 13, 2011 9:17 am
Weather for Sunday ,if its right. Rain in the afternoon 25 to 30mph s,w, wind. Might get to run in morning Pel with any luck :D rich
Post by mgbv8 » Thu Jan 13, 2011 12:37 pm
Our local forecast says great up to sunday then crap on sunday. National says what you say. Pod will just do what it always does mate. Either rain solid or be dry and then rain just after the track opens :)
Or chuck one of its surprises like twice last year when the track was empty and it stayed dry all weekend.
I'm going to knock up the extra big breather tonight just in case she gets let loose flat out..
bones
Post by bones » Thu Jan 13, 2011 12:55 pm
I looked up weather for Poddington or Irchester, hope it stays dry for you. If you run on Sunday and get into the 9s and engine holds up, what you going to do for the rest of the season. ?? :D rich
Moderator Gold
Moderator Gold
Post by kiwicar » Thu Jan 13, 2011 1:33 pm
Head for the 8's :D at a guess . . . . can you get a 650 shot of nos into a rover engine??
Post by mgbv8 » Thu Jan 13, 2011 4:15 pm
kiwicar wrote:Head for the 8's :D at a guess . . . . can you get a 650 shot of nos into a rover engine??
I'll give it a try soon i hope :lol:
Post by mgbv8 » Thu Jan 20, 2011 9:49 pm
Well!
I tried a 450 shot and got a backfire. I'm still trying to figure out why. But i reckon if I had a blower fitted it wouldnt have happened :)
Back out next Sunday to try again??
Moderator Gold
Moderator Gold
Post by kiwicar » Fri Jan 21, 2011 6:48 am
Hi Perry
"But i reckon if I had a blower fitted it wouldnt have happened "
I like this attitude, that is the spirit! being a more pessimistic sole, when you get the blower fitted I will buy you a blower restraint if you want :lol: :nutz
When are you running on Sunday? if I'm not collecting my gearbox (which is looking like the case) I shall come and join you and investigate just how slowley a rover 75 will do a quarter mile. :lol:
best regards
Post by mgbv8 » Fri Jan 21, 2011 10:27 am
I'll be waiting for the gates to open at 8am Mike.
And next week I have a meeting with a potential blower sponsor to work out a deal for this year??
Now!!
How do I fit methanol to a Rover V8 ?? :lol:
Moderator Gold
Moderator Gold
Post by kiwicar » Fri Jan 21, 2011 11:13 am
Hi Perry
You'll need one of these
http://cgi.ebay.com/ebaymotors/FUEL-INJ ... arQ5fParts
and one of these
http://cgi.ebay.co.uk/Imperial-High-Spe ... 68c6dd927d
:chase
PS it looks like I may be finally getting my box on Sunday after all
Post by mgbv8 » Fri Jan 21, 2011 8:58 pm
Show me a diagram of how this system injects fuel on my Rover??
Do I need to change to EFI system?
Do I ditch the carb altogether?
HELP!!!
Moderator Gold
Moderator Gold
Post by kiwicar » Sat Jan 22, 2011 8:35 am
Hi Perry
I can't post diagrams for you but but I can pop over at some stage and draw it on a fag packet. In the meantime I can describe the installation.
For a system without a blower you need to mount an injector nozzel in each runner in your manifold, I think you have an open plenum one and that would be ideal, bung the carb in the back of the garage, replace it with a throttle plate of some sort, put the NOS system back in below the throttle plate.
Find somewhere to mount the injection pump and either drive it straight off the cam or drive it with a belt off the crank and a reduction of 2:1.
There is a throttle/barrel valve that controles the part throttle mixture and needs to be mounted close to the throttle so it can be opened and closed by the throttle. Most systems have a high speed bypass valve, this needs mounting aswell.
You then connect the whole lot up using fuel pipe, the nozzels are fed from a distribution block that is plumbed in after the high speed bypass valve that in turn goes in after the throttle valve that in turn is fed by the pump. You need a feed from the tank to the pump and a return to the tank that will probably have 3 seperate returns plumbed into it.
Return to “Nitrous Oxide Area ”
