Twisted sanity controller
General Chat About Nitrous Oxide.
billo353
Post by billo353 » Sat Jul 11, 2009 1:29 pm
Hi, anybody know where I can download/get a copy of instuctions to fit a twisted sanity progressive controller. Thanks in advance.
bones
Post by bones » Sat Jul 11, 2009 1:42 pm
Hi, is it the old type, got 3 dials on it, or the new one, ive got the old one,4 wires coming out of it :) rich
billo353
Post by billo353 » Sat Jul 11, 2009 4:11 pm
Its the old type with 3 dials, thanks.
bones
Post by bones » Sat Jul 11, 2009 4:34 pm
all ive got is a rough drawing of the wiring that someone did for me, BLACK is earthed, RED to the arming switch and from that to 12v supply and to both solenoids, BLUE goes to other side of soleniods and the WHITE goes to the throttle switch,, dont know if it helps :? rich
billo353
Post by billo353 » Sat Jul 11, 2009 7:55 pm
Ta very much,I have a Sniper kit on a 427 SBC, and its all or nothing, a real handfull. I have been offered this (free!!) so thought I'll give it a try.?? thanks again,Bill.
bones
Post by bones » Sat Jul 11, 2009 8:19 pm
ive got a cheater system and used the controller,but nos solenoids dont like to be pulsed,the car ran horrible, nos was on and off all down the strip. it knocks them out pretty quick aswell,and they need rebuilds about every 20 uses or so, thats why ive gone 2 stage instead, but yours could be ok :) rich
billo353
Post by billo353 » Sat Jul 11, 2009 9:00 pm
Thanks for all your advice, I will let you know if its better/worse.
Post by mgbv8 » Sun Jul 12, 2009 8:29 pm
Bill!
If you have an analogue multimeter you can test the controller.
The wiring diagram Bones has is correct so it will do you.
Mind you, I was pissed when I drew it :lol:
Set your start power to minimum. Set you final power to 100% and set your build time to around 4 seconds.
Connect your meter to the output wire and earth. When you activate the controller you should see the voltage start to rise from low volts to 12volts steady after 4 seconds.
This will give you indication that it is actually pulsing.
If you are using the small powershot solenoids on your Sniper kit it will work. But as Bones say's. They dont like being pulsed and will wear quickly.
Perry
billo353
Post by billo353 » Tue Jul 14, 2009 6:54 pm
Thanks for that.
Return to “Nitrous Oxide Area ”
