3.5 v8 supercharge options
Posted: Thu Nov 12, 2020 7:33 am
by murray
Good day all.
I have a mgb gt with stock V8 and a 4 barell holley carb. I have given some consideration to a supercharger. I think the Low compression standard 150hp 3.5 would do well with a boost.
I have seen a few on line but would like some advice from anyone who's stuck a charger on a similar engine. Pros and cons.
Many thanks.
Re: 3.5 v8 supercharge options
Posted: Thu Nov 26, 2020 1:56 pm
by SuperV8
I supercharged my 3.5 using a centrifugal supercharger, these can mount anywhere on the front as long as the pulleys line up.
I did find the V belt was unsuitable to transmit enough power without slipping though.
Even a modest boost pressure gave a good 'seat of pants' improvement.
the benefit of the centrifugal supercharger is it won't interfere with your bonnet, however to get the most out of any supercharger/turbo - fuel injection and mapable ignition are better than carbs and mechanical dizy.
Posted: Thu Nov 26, 2020 5:41 pm
by Blown v8
My first supercharged rover was a 3.5 with Land Rover pistons, IIRC 8.5 compression, I had a Wade ro34 about 5-6 lbs of boost,
Certainly ran ok, but power ,especially boosted power is addictive, and before you know it,
You’re hooked, you have been warned
Posted: Thu Nov 26, 2020 6:58 pm
by murray
So taking that its a standard spec 150hp engine. And assuming the engine is in good working order, would I get away with do little else. And would it pump through the holley
Posted: Fri Nov 27, 2020 5:31 pm
by Blown v8
Yes, as long as you don’t have to much boost, get it on a rolling road to sort out the timing, (don’t ask me how I learnt the expensive way)
Put a grade cooler spark plug in, a boost referenced carb is best, but a good rolling road will sort it out (fatten it up) and make sure you’re ignition system is top notch
Posted: Fri Nov 27, 2020 10:24 pm
by Coops
My 4.8 with a Procharger D1SC centrifugal supercharger fitted, for an idea
Posted: Thu Nov 02, 2023 7:07 am
by Chris1976
Blown v8 wrote: ↑Thu Nov 26, 2020 5:41 pm
What size carb did you get boost referenced Sir? @Blown V8
Posted: Thu Nov 02, 2023 5:15 pm
by Blown v8
I had a 390cfm Holley, Real Steel upgraded it for me, but that was a lot of years ago
