Rover 3.9 turbo, clutch recommendation?
Pxr5
Post by Pxr5 »
3.9 rover in a MGB r380 box, the car is for road use, road tires about 360bhp, whats a good value clutch that will hold this level of power,? thanks
Re: Rover 3.9 turbo, clutch recommendation?
It's more maximum torque which determines the clutch needed. Is it forced induction?
Pxr5
Post by Pxr5 »
yep turbo...
Regular AP paddle clutch should hold it ok, and car is probably fairly light ?
I used one years ago and it held well on my much heavier car.
Pxr5
Post by Pxr5 »
Are the paddle clutches a little harsh?, any part numbers for this? thanks
sidecar
Post by sidecar »
I use a Helix paddle clutch in my 4.6, you can get a bit of a judder just as the clutch bites when you are pulling away from a standstill but after that it's OK.
They are a little yes.
For a daily driver....more so if you see traffic, it would be very annoying. For an occasional fun car, not really a big deal as they're not really that bad in most cases.
Realistically in this day and age, there should be dozens of organic based options to hold the power, but just not sure anyone has ever bothered. But for modern Jap stuff, 4wd etc...getting a good organic clutch that will handle 500hp all day long is pretty easy and they're smaller diameter than the RV8.
So for the RV8 getting a daily driver clutch to handle only 400hp should be very easy.....should.
Might be worth calling the likes of Helix etc
Or maybe the likes of TTV could offer something
http://ttvracing.com/clutch-types/ttvr-road-clutches/
http://ttvracing.com/product/rover-v8-l ... -5-clutch/
Pxr5
Post by Pxr5 »
Thanks for that, no one running a car with similar specs care to give me the details for what they are using? please?
JP.
Post by JP. »
Running a 10.5" McLeod street strip kit from RealSteel for years now. Sinter Organic full face for years on the Supercharged. Superb on the street. Just handles like a daily. Perfect on the strip.
'73 Ford F250, 6.7ltr V8
Building a GT40 mk2
The likes of the larger diameter US offerings would be a good idea.
Or plain and simple AP paddle clutch
https://www.apracing.com/product_detail ... _only.aspx
Pxr5
Post by Pxr5 »
Thanks for the input, I see JEGS in the US do a mcleod 10.5" plate & cover with post+import dutys etc it comes out at £239.12p, sounds like the way to go, BTW its listed as a Dodge Charger 69 part....
I'm using a Helix organic clutch+cover in my 4.6 supercharged Dax Rush, probably 350+hp, grippy rear tyres but only 700kg so maybe a little lighter than an MGB?
Clutch works great, holds the power fine, although it is rather heavy when doing lots of stop starts, but it smooth and progressive.
Don't know part numbers, just at the time when I phoned Helix they told me it was the same one they use in the Tuscan race cars.
It has double diaphragm springs.
Blown v8
Post by Blown v8 »
I had the 10.5 Mcleod clutch for years on mine,BUT ,there's a limit,I found that,and now gone to a ceramic clutch,
Organic are good to about 400lb IMHO
Running Mcleod RST twin plate set up in mine,
nice on the road to use just like standard clutch,
The attachment c8.jpg is no longer available
The attachment c3.jpg is no longer available
Blown v8
Post by Blown v8 »
The remains of my double clutch !
Beware COOPS, your new blower is going to make more POWER 😀
Return to “Forced Induction”
