Page 1 of 2
Borg Warner EFR 7670 twinscroll any good for a V8 ?
Posted: Wed Mar 18, 2015 9:33 pm
by Mark
Spotted this on Passion Ford...
http://passionford.com/forum/ford-rs-co ... l-new.html
Got me thinking
Would something meant for a high power 4 cylinder work OK on a small block Ford ?
I worry about the exhaust housing chocking the engine at high revs but it does have an AR of 1.05
Any thoughts ?
Posted: Thu Mar 19, 2015 7:35 am
by chodjinn
No. The exhaust housing will choke the engine. You could run two of them though.
For something like a small block ford - I assume it's a 5 litre - you want a big turbine housing. I've got a 4 litre 1uzfe and I've been looking at Holset HX50/55 turbos recently with 22cm housings. You could buy three decent holset turbos for the asking price of that one you posted.
Try compressor racing, he's a one man band but gets some big turbos in. He's currently got a monster Garrett GT4594 turbo for £450 which is a bargain, with just dyno runs on it, that would work a treat on a small block! Proper man sized turbo! I would have bought it but it's just a bit too big for my engine and power level aims.
Posted: Thu Mar 19, 2015 8:51 am
by chodjinn
Posted: Thu Mar 19, 2015 3:22 pm
I would have no worries at all about using that on 5.0 with an upper limit around 600hp
It's a T4 housing with reasonable sized turbine for the compressor and it will not choke unless you're pulling some serious rpm's
I'd have no hesitation using it, it should spool well and make decent power.
But there are also cheaper alternatives for a single that would be better suited, but a lot depends on the goals. If it's a torque monster then the EFR would work great. If you're more into revving, then there will be better units.
Cheap and cheerful BW S366 would be a good one for a cheap single, but it does depend on your goals.
Posted: Thu Mar 19, 2015 3:45 pm
by chodjinn
Right well my bad then. Seems a lot to spend on a turbo tho when there are far better available for a lot lot less.
Posted: Thu Mar 19, 2015 3:56 pm
chodjinn wrote:Right well my bad then. Seems a lot to spend on a turbo tho when there are far better available for a lot lot less.
I'd agree
It isnt perfectly suited by any means, but if you wanted a fast spooling, lots of torque for towing etc then yes it would be a good choice.
It's not that there are far better for less....just better suited for the specific application for less. EFR's are great turbos though.
Compressor wise, it's only just larger than a small GT35, but their turbines are supposed to flow a lot more than other turbos for any given size.
I've a good used GT4094R here. It has an impeller with a 67mm inducer but the turbine is still a similar size to that 7670
It's impeller would support close to 850 with the right build ( not a single 5.0 though )
It would probably work fine on a 5.0 too, but definitely be slower spooling than the EFR listed.
Again...really depends on your goals though.
Posted: Thu Mar 19, 2015 6:42 pm
by Mark
Just thinking out loud really...
The Cossie boys rave on about how good these new Borg Warners are.
I have a roller cam Ford 5.0 with a 331 stroker kit.
The stock block is weak and will not take any more then 500bhp without splitting down the middle from what I've read.
So if I went turbo, it would to be low boost or splash a load of hard earned on an aftermarket block.
Any turbo maps I look at the pressure ratio at low boost is usually off the bottom of the efficiency island
If I can't run high boost a quick spooling turbo would make it more fun!
Posted: Thu Mar 19, 2015 6:51 pm
There are cheaper options that would get the job done, but he isnt asking a lot of money for the turbo either for what it is.
As an example of a BW journal bearing, billet wheel etc.
I use a pair of these, and they're keenly priced here, he's asking £1450 for a brand new EFR7670 too
http://www.garagewhifbitz.co.uk/borg-wa ... -4231.html
This has a larger impeller than the 7670, similar turbine. It would spool very fast on a 5.0 and with more top end potential
or there are lots of cast wheel options
http://www.agpturbo.com/s3-s300-series/
Posted: Thu Mar 19, 2015 7:41 pm
by Mark
Thanks for the info
I thought you were running a Vortech ?
Posted: Thu Mar 19, 2015 9:53 pm
I was, switched to a pair of turbos last year.
Just needed more power, more silence, less belt woes etc.
Posted: Fri Mar 20, 2015 12:29 pm
by SuperV8
You would not be able to make the most of a twin scroll turbo on a cross plane V8 as the exhaust pulses can't be optimised. Not to say it wouldn't work, just that the twin scroll turbo costs more and you won't be able to take advantage of the twin scroll housing.
That's why the modern V8 turbos have the turbos in the V so the exhaust pulses can be used to optimise twin scroll turbos.
I suppose you could use two twin scroll turbos on a flat plane V8!
Posted: Sat Mar 21, 2015 9:23 am
by Mark
I had wrongly assumed that running one bank into each half of the turbo would do the trick
Posted: Sat Mar 21, 2015 9:27 am
by Cobratone
I have no knowledge on turbos so excuse the ignorant question but is it ok to run a single turbo off one side of a V8 or will the obstruction on one side upset the engine??
Posted: Sat Mar 21, 2015 9:47 am
by chodjinn
Mark wrote:I had wrongly assumed that running one bank into each half of the turbo would do the trick
There's nothing wrong with doing that it will work fine.
Posted: Sat Mar 21, 2015 9:48 am
by chodjinn
Cobratone wrote:I have no knowledge on turbos so excuse the ignorant question but is it ok to run a single turbo off one side of a V8 or will the obstruction on one side upset the engine??
Yes you can do that, as long as the turbine isnt restrictive. several manufacturers have done that. I think saab did it relatively recently on a v6?
