Intake pipework
topcatcustom
Intake pipework
Post by topcatcustom »
Is 1.6mm walled ally tube thick enough for low boost pipe work? Want to use 3.5" or 4" tube and it's only available in 1.6mm or 3mm wall.
TC
katanaman
Post by katanaman »
Should be fine. I know a car that is running 2 bar with 1.6mm. That said if you went for the 3mm you would be able to bend it saving having to get bends and piece it all together.
topcatcustom
I had decided to go with the thinner stuff, but may do a couple of trial welds before ordering as butt welding thin ally can be a pain! I've found a company who will supply me with 3mm mandrel bends which would definitely be the easiest option as 3mm is easy to weld, but it would be heavy!
Oh- how could I bend the 3mm stuff myself?!
TC
katanaman
Post by katanaman »
3mm should be just about thick enough not to crush in a none mandrel bender. It might ding slightly but that shouldn't matter since your using such large diameter pipe. 1.6 will weld easy enough if you have a TIG. I regularly weld 1mm with no problems. You will never bend it though lol.
Return to “Forced Induction”
