Rover 3.9 turbo, clutch recommendation?
Pxr5
Re: Rover 3.9 turbo, clutch recommendation?
Post by Pxr5 » Tue Oct 30, 2018 8:49 pm
Coops, how much was the twin plate clutch & where did you buy it?
Post by Coops » Tue Oct 30, 2018 8:59 pm
which clutch was that mate?
Rotrex C38-91 supercharger and Cossie RS500 Intercooler @ 14psi of Boost. 404 RWHP, (4.6)
New Forged 4.8 V8 kitted out with the dogs Cajones of parts and a procharger D1SC. 2017 :D
Post by Coops » Tue Oct 30, 2018 9:00 pm
nearly £900 then the flywheel needs machining to suit the intenter ring,
Realsteel stock the parts,
Post by SuperV8 » Wed Oct 31, 2018 11:27 am
I presume if you need to drill/machine your flywheel you also need to factor in re-balancing.
Post by stevieturbo » Wed Oct 31, 2018 10:45 pm
If it was just re-drilling fixing holes for a clutch...really shouldnt make any odds...and of course you'd assume it was balanced to begin with.
As for machining, again it depends what work was being done. I'm sure most people years ago who had theirs lightened by removing loads on a lathe never bothered re-balancing, which for that work really should be done.
TTV seem to offer flywheels for the larger diameter clutches, or maybe they make one of their clutches too...give them a shout
Post by Coops » Thu Nov 01, 2018 5:58 am
Yeah sorry redrilled I had mine faced while it was being redrilled hence the machining bit and was all rebalanced
russell_ram
Post by russell_ram » Thu Nov 01, 2018 8:28 am
I have a twin plate quartermaster unit and custom EN14 steel button flywheel/starter ring that I might be persuaded to let go. All engineered as a matched set as a direct replacement for std SD1 components. Spec'd to go on the back of a 5.2 wildcat motor. Bought it many years ago but never used, so long ago that I can't remember the exact spec LOL. I can dig it out later and do some pics if you're interested.
Pxr5
Post by Pxr5 » Thu Nov 01, 2018 8:53 am
Hi, what money would that be? Im after a unit that will handle about 370bhp, it sounds like its more clutch than I need, thanks for the offer....
Return to “Forced Induction”
