Sprintex S/C, what grease?
Fed_up_Stag-owner
Post by Fed_up_Stag-owner » Sun Sep 10, 2017 5:01 pm
Hi All,
The Sprintex supercharger on one of my RV8s has been running well for 10k+ miles in my ownership. I have changed the oil for the front bearing, I should probably grease the rear bearing.
Can't find much info re: grease spec, so I'm probably going to use Red Line CV-2 synthetic grease, comments and suggestions please!
Post by SuperV8 » Wed Sep 13, 2017 9:57 am
Can you see what bearing it is? number? Does it have a dust shield?
I think I would find out what bearing it is and look for a spec sheet for that bearing at the max rpm for your use.
[/quote]Sprintex recommends Redline 75W90NS
http://sprintexusa.com/faq/
Looking at that thread:
http://www.380db.com/forums/thread-view ... 68&start=1
it looks like the rear bearings are sealed. No idea if yours is a similar unit? Replacing the grease/oil in a sealed bearing will be difficult to get the correct quantity/spec. I think if it was me I would replace the bearings or leave as is if there is no play and they are smooth, and not try to re-pack them.
Fed_up_Stag-owner
Post by Fed_up_Stag-owner » Sat Sep 16, 2017 6:56 am
Thanks SuperV8,
The 75W90 will be for the front bearing (it has an oil reservoir), there is a grease nipple for the rear bearing. I'll have a look for part numbers
Fed_up_Stag-owner
Post by Fed_up_Stag-owner » Sun Dec 10, 2017 7:51 pm
Finally got back to this, can't see any part numbers without dismantling, so I've bought the Redline CV-2 Synthetic Grease, operating temp up to 500'F is hopefully enough
Return to “Forced Induction”
