Eddy 1404 flooding
Stagrover
Eddy 1404 flooding
Post by Stagrover »
Hi I’ve been chasing poor running and idling for months on a rebuilt 4.6l Rover.
I’m using an offy dual plane manifold that was fine for 15years on a 3.9l with the same carb and distributor. I changed to sidecars suggestions on the needles and springs at the weekend without improvement.
I’ve just reset the float heights but found no improvement on a quick cruise round. I can’t detect any air leaks around the base and 4 hole heat spacer but decided to take the carb off and inspect the gasket in case there was an internal tear. No damage but it has revealed that the 2 front barrels and the left rear are all dry and using any fuel going in but the right rear is very wet for some reason.
I would, if possible, appreciate a layman’s explanation of what could be the cause.
Fuel consumption is getting worse probably explained by the excessive fuel getting into the wet inlet.
Thanks in advance
Stagrover
Re: Eddy 1404 flooding
Post by Stagrover »
Having left the carb off overnight the “wet” manifold port is still wet and feels oily.
Can’t tell from smelling if it’s oil or antifreeze.
Any thoughts on identifying a source?
Has anyone heard from Sidecar recently? He seems to have taken a break from passing on his enormous practical experience?
Robrover
Post by Robrover »
This is what my 1404 is set up to run on my 4.6 (on dyno):
083 main primary jets
089 secondaries
6347 rods
Silver step up spring (which activates at 8 in hg of vacuum)
This is with big valve full race Buick heads, Scorcher dissy set at 10 degrees, Crane cam and Edelbrock inlet manifold.
