Fuel arrangements for SU carbs
EricCartman
Post by EricCartman »
Hello all,
Apologies if this has been done before but after scouring the internet for some time, I could not find a satisfactory answer.
I have a London Taxi as a project car. I’m putting in a 3.9 v8 with SU HIF44 carbs. The taxi was fitted with fuel supply and return lines.
Basically, what I want to know is, what should the ID of these pipes be? I will use a Facet Posiflow pump (3.5 to 5 psi) with non return valve and a prefilter. I’m guessing 8mm would be good for the supply but what about the return? Should it have a restrictor in it? Would I also need a regulator?
Sorry if this seems a bit simple but I’ve no experience with this sort of thing.
Many thanks.
1997 London Taxi 3.9l sleeper with SU carbs. Where to guv?
Re: Fuel arrangements for SU carbs
I am sure that SU's don't have a fuel return. Once the float bowl is full, the needle shuts off the supply, and the pump stops delivering because it can't overcome the needle valve.
They have an overflow in case the needle valve fails in some way.
As for pipe ID, I would just match whatever the carb inlet is.
P.S. Got any pictures?
harvey
Post by harvey »
ChrisJC wrote:
Sun Jun 07, 2020 1:28 pm
Rover P6B does.
harvey wrote:
Sun Jun 07, 2020 1:51 pm
Rover P6B does.
Yup - but a mechanical pump. The traditional SU pump would just stop when the carbs are full.
The SD1 has an electric pump in the tank. No return with that. The injection version an external high pressure pump with a return.
harvey
Post by harvey »
I was right with the part I quoted and answered, but you're right about the SD1, and the clue, "HIF44", was in the original post.
harvey wrote:
Sun Jun 07, 2020 3:05 pm
I doubt it matters what version of the SU carb.
The P6B was dreadfully prone to fuel evaporation problems. I'd guess the fuel return system was an attempt to reduce that, with the simple and cheap mechanical pump.
EricCartman
Many thanks. So I think I’ll just use a single 8mm pipe and route it away from the exhaust and see how it goes. The baby 1.5 to 4 psi facet pump may be suitable in this case. I’ll put up some pics when it’s finished...
al mackenzie
Post by al mackenzie »
I've always wanted a sleeper black cab with a V8 transplant! Welcome along, look forward to seeing your ride when you get it all sorted out Eric!
'72 Rover 3500, 6yr back-to-the-bare-Base-Unit nut & bolt resto finished in time for her 40th birthday June 2012!
