Page 2 of 3
Posted: Mon Apr 27, 2009 1:20 pm
Moly lube is the black stuff with Molibdinium disulphide in it, cam lube is normally red or white depending on how long the assembled engine will be in storage. If you need some ARP thread lube I probably have a sachet of the stuff at home, let me know an address via PM and I'll have a look tonight.
Posted: Mon Apr 27, 2009 1:26 pm
No, nothing like it.
Its basically just Moly grease ( CV's )
Cam lube is more like a thick gear oil.
Posted: Mon Apr 27, 2009 1:37 pm
by topcatcustom
Can I not just use grease then? I have put the studs in by hand and will nip them up lightly with an allen key, and only have to torque up the nuts but can't see why they have to sell you a "special" grease to do so!
Posted: Mon Apr 27, 2009 1:46 pm
topcatproduction wrote:Can I not just use grease then? I have put the studs in by hand and will nip them up lightly with an allen key, and only have to torque up the nuts but can't see why they have to sell you a "special" grease to do so!
ARP fasteners always come with ARP Lube
Do you use the same grease in every aspect of your car ? I'd hope not. And they clearly give instructions for torques with motor oil too. What is the problem ?
Posted: Mon Apr 27, 2009 2:20 pm
by topcatcustom
I got the ARP's from someone on here a while ago as they got merlin heads and wouldn't fit- hence why no paperwork or lube, so I have no idea what different figures or advice they quote on the packet when you buy them new!
Posted: Sun Mar 27, 2011 2:38 pm
by jimbob
Just picked up a new sets of studs for my Rover heads, and it states 85 ft lbs x 3, i think its a little high considering its an Alu block.
Any ideas?
Thx,
Jim
Posted: Sun Mar 27, 2011 2:43 pm
jimbob wrote:Just picked up a new sets of studs for my Rover heads, and it states 85 ft lbs x 3, i think its a little high considering its an Alu block.
Any ideas?
Thx,
Jim
The studs are 7/16" anyway. So as long as there is plenty of thread engagement, it will be fine.
Subarus use 11mm studs and they go to 85 no problem. LS engines are also 11mm studs, and use the same figure.
The torque they state is pretty much directly related to fastener diameter.
Think I only did mine to 80lbft though lol
ARP bolts.
Posted: Fri Jan 24, 2014 10:15 pm
by Dixie6789
Evening.
Just got my re-bored block back from Realsteel. Also brought a set of ARP main cap & big end studs/nuts and bolts for 4.6 big ends. Also a set of ARP X-bolts.
My question:- Are these ARP studs etc ok to use? I have heard that when using them I need to get the crank journals line bored, I just cannot see why, using these studs must surely be a good thing. Des Hammills book isn't clear, and David Hardcastle doesn't go into detail either way.
Lastly, can I use the torque values in the LR workshop manual?
thanks Mark
Posted: Tue Mar 25, 2014 11:07 pm
by Dixie6789
Got all my ARP studs in and tightened up.
75 ft/lbs for the mains, 90 ft/lbs for the rear bearing.
40 ft/lbs for rod bolts. All with ARP grease.
Must have worked ok because everything turns smoothly and 0.002" between rods and crank end float at 0.002".
Quite pleased.
Now on to the heads.
arp stud
Posted: Wed Apr 30, 2014 2:43 pm
by drowssap
I know this is an old post but ARP makes head studs for new and old rover engines. there are different numbers for 3.5, 3.9 4.2 than 4.0, 4.6 the later being longer.
Re: ARP Torques
Posted: Fri Jan 31, 2020 7:32 pm
by Mc Tool
I put main studs in mine because when I got the motor the caps had been fretting . Line bored the block . The head studs I fitted as per instructions ( no lube supplied so I used moly sulfide assy grease) and 2 or 3 studs have pulled up the threads . When getting close to max torque things suddenly got loose giving the impression it had pulled the stud out. I leaned on it a bit more and I did reach max torque ,but what to do now .....run the motor and hope for the best or find another block. I used composite gasket.
Re: ARP Torques
Posted: Sat Feb 01, 2020 12:06 am
by garrycol
Why would you need a new block - if the studs have pulled just put a "thread sert" in and redo. (do not use heli coils as they are not strong enough (or at least the metal in the block is not strong enough.
Definitely remove the heads and take the studs out and check the threads and go from there.
Re: ARP Torques
Posted: Sat Feb 01, 2020 7:02 am
by Mc Tool
That was a good reply as I was just pricing up a helicoil tool and inserts to do the whole block. The thing that gives me the shits is how to make sure the hole is drilled and tapped square ( doesn't fit in my drill press
Im not surprised they pulled as the block thread is 7/16 unc and the nuts on the stud are 7/16 unf .
Should one slightly counter sink the stud holes?
Thanks garrycol.
Re: ARP Torques
Posted: Sat Feb 01, 2020 9:12 am
by garrycol
Dont use helicoils as they will pull out. For about a third of the price of buying kits to make the repair just google a Mobile Thread Repair Service near you and they will come and do it for you - always a top class job.
Here is mine.
Garry
Re: ARP Torques
Posted: Sat Feb 01, 2020 9:13 am
by garrycol
Also - if the studs pulled out you must have over torqued them - I would not go over 90ft ibs and make sure the threads on the nut end are lubricated as well as the threads that go into the head.
