What can you tell from my heads and bores?
Posted: Sat Jan 15, 2022 10:56 am
by rich112
In the process of stripping my 4.6
It appears to have non standard rockers.
Alas my cam is toast as one of the tappets is badly dished.
I'm running a Holley 390 on a JWR manifold.
Does the state of the combustion chamber, valves and bores tell you anything? A little rich on 7,8?
Re: What can you tell from my heads and bores?
Posted: Sat Jan 15, 2022 10:57 am
by rich112
Here's the knackered tappet.
Posted: Sat Jan 15, 2022 10:58 am
by rich112
And some of the bores:
Posted: Tue Jan 18, 2022 8:17 pm
The colour of the combustion chambers doesn't seem overly different to the ones I've seen. It wouldn't set off any alarm bells for me.
The bores appear to still have a cross-hatch?, but some scoring too? Hard to tell from the pictures.
Posted: Tue Jan 18, 2022 11:39 pm
by rich112
ChrisJC wrote: ↑Tue Jan 18, 2022 8:17 pm
The bores have some vertical scratches, very slight and the bores are slightly oval.
Just tossing up wether to just run a flex hone down them or send the block off for a proper hone to get perfectly round again.
Posted: Thu Jan 20, 2022 6:40 am
I suppose you have a problem in that the 4.6l engines cannot be bored oversize (according to Land Rover). This is a bit of a dilemma. I would want to get it rebored up a size and get oversize pistons, but that's not possible!
Posted: Thu Jan 20, 2022 11:41 am
by paul c
Turners have oversize pistons for the 4.6. I have a set here I was going to fit in my engine.
Posted: Fri Jan 21, 2022 7:03 pm
by rich112
Looks like I have a couple of oval bores. 7 and 8 are 0.1mm over 94mm.
I'm already on B size pistons so looks like new liners...
I guess I'd have to do all 8 and then put in new pistons and rings too. It's getting expensive!
