RV8 3.9 Timing Cover on a 4.6 Block
DEVONMAN
Re: RV8 3.9 Timing Cover on a 4.6 Block
Post by DEVONMAN »
4.6 sump and oil pickup needs to be changed to a 3.9 type also.
minorv8
Post by minorv8 »
OK, here is the crank spacer your will need with 4.6 engine and 3.9 timing cover.
Rough dimensions:
OD 44,5 mm, length 29,8 mm
ID (diameter of bore) 36,9 mm, depth of bore 18,6 mm
diameter of bolt hole 16 mm
minorv8
Post by minorv8 »
As for the cross bolt, I assume that you mean the RH side bolt for the front main bearing cap ? I have had both ancient Range Rover cover (circa 1975) and later SD1 type range Rover cover. Neither of these required any mods for the cross bolt. My current block is a small mains Morgan 3,9 with TVR 500 internals. This block had bosses for cross bolts but were not machined from the factory. Instead, they were machined at a later stage but with a 7/16 thread in the caps. Why, I don´t know ? But the block was new and never used. Maybe someone found out that factory bolts could not be used. I used cylinder head bolts.
I took a photo showing the bolt head (lurking behind the ground cable) and oil pump. There is plenty of clearance. Having said that, there are different oil pump covers and some may not clear the cross bolt head. Yes, this is not a 4.6 block but I have not had issues with them either.
