3.5l v8 efi 1983 kit car idle problems and questions
Posted: Sun Mar 10, 2019 9:50 pm
Good evening everyone
Just signed up here as i have a kit car with the rover v8 fitted.
the car is an evolution roadster built in 2002 with all the bits taken from a rover sd1 on a 83 plate (A)
I've had the car a few weeks now and spent the weekend having a proper look over it, its got some issues and i thought this would be the best place to ask for some help.
today i replaced all 8 spark plugs and im awating a distrubutor cap and leads and a coil, it had a misfire but didnt when i bought it so changed out the plugs and its all good now, however the problem is on tickover once its hot, once i rev the engine as it comes back down to idle it doesn't drop fast like it should when its cold and stick to idle, it stays about idle about 1500rpm.
today i removed the plenum chamber, cleaned it, re sealed it, re fitted it, had all the breathers off and cleaned and checked those, unplugged the 9th injector on the plenum and blanked off the fuel pipe also. Also removed the extra air valve, cleaned it and refitted.
it has a FSE power boost valve fitted, i removed that opened it up cleaned it out didnt find anything of issue there. After much tinkering and messing around the TPS on the plenum butterfly was clicking when i moved the wires around it and was making the car run differently, i removed it to inspect it and the green wire 1 of 3 that goes into the tps just came away, so i opened it up and its pretty much knackered, i ran the car with out the TPS and unplugging the breather pipe which comes from the O/S rocker cover and the car starts up perfectly, drives nice, and when i rev it drops back to idle nice and quick like it should. Im a mechanic by trade and i know how the TPS works and with ecu's etc etc, its just confusing me because all day messing around with it, with the breather attached and the TPS on its not sat at idle, when they are removed its running absolutely fine and this doesnt make any sense to me haha.
so can i just stick a filter on the end of the butterfly breather to atmosphere, and am i going to cause any damage to the engine running with out the TPS? It's totally unplugged and not on the engine now as its broken. Out driving it pulls hard in every gear with no problem, no lack of power at any point in the rev range.
any help on the matter would be appreciated.
i did read they don't sell those TPS sensors any more so a modified one from another engine can be used.
